Old 10-29-2014, 03:30 PM   #37
Ryze268
Ryze268's Avatar
Drives: 2002 JDM Vitz 1.3
Originally Posted by Bluevitz-rs View Post
You'll need to back the idle adjuster screw off a bit. It's set to idle a 1.8L.
Sent from my iPod Touch
I did, it's completely backed out
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete
Follow me on Instagram:
instagram.com/itzkingjustin
Ryze268 is offline   Reply With Quote
Old 10-29-2014, 04:30 PM   #38
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
You must have a vacuum leak somewhere then.
Old 10-29-2014, 05:41 PM   #39
Ryze268
Ryze268's Avatar
Yes, I'll make a fresh gasket tomorrow.
Something I noticed is that my rev limit increased. It's topping out at 6700 rpm now, Not sure how that happened.
Regarding the cable being too short, I think this will have to be my solution;
Old 10-29-2014, 07:32 PM   #40
Bluevitz-rs
Did you port match the intake manifold.
Old 10-30-2014, 06:10 PM   #41
Ryze268
Ryze268's Avatar
Yes I did, when I took it for a spin the engine felt more responsive. The hesitation I had with the smaller TB was no longer there.
I made a new gasket and it still wouldn't idle below 1500 rpm, I grew frustrated and put back on the stock TB.
I'm going to leave it to continue my turbo build.
I'll revisit this swap when I figure out where the leak is coming from.
Old 10-31-2014, 04:12 PM   #42
Bluevitz-rs
It could be the idle air speed controller.
I know the bypass port look very different between the two throttle bodies.
Old 10-31-2014, 04:13 PM   #43
Bluevitz-rs
If they can be swapped between the two, maybe that's the problem.
Old 10-31-2014, 08:42 PM   #44
Ryze268
Ryze268's Avatar
Is that the sensor which is on the side with the coolant lines?
wtb stock throttle body , cheap blacksandiegovitz Willing to Buy by private party 0 09-21-2012 10:32 PM
THROTTLE BODY SWAP NO CEL!!!! kou Performance Modifications 53 02-01-2011 04:01 PM
FS- 1ZZ Throttle Body, Spacer, NST SSK MGargano Items for Sale by private party 9 09-01-2010 08:48 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
toyotafest 2007 esquiva Photo-Video-Media Gallery 36 05-15-2007 12:03 PM
