Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > Yaris TS Talk
Old 02-02-2015, 01:09 PM   #19
Originally Posted by sebastianroher View Post
Any idea on how to get it out since I rounded it? Also, do they sell them?
Toyota does sell the replacement filters (and the cover bolt), but they are easy enough to clean. If you stripped it you will have to use an extractor to get it out.
Old 02-02-2015, 01:10 PM   #20
sebastianroher
Drives: 2009 Toyota Yaris Hatchback
Do you have a p/n for that bolt?
sebastianroher is offline   Reply With Quote
Old 02-02-2015, 01:12 PM   #21
I'm not where I have access to that today. Your Toyota parts dept can easily look it up for you.
Old 02-02-2015, 01:14 PM   #22
sebastianroher
Right on I'm gonna check that sensor tonight and let you know. Anything else I should check?
Old 02-02-2015, 03:16 PM   #23
sebastianroher
I checked the resistance of the camshaft position sensor and I get 1.172k Ω cold. The manual says that is should read 1,630 to 2,740 Ω cold. So maybe the camshaft sensor is keeping it from starting? The first one went bad because of oil and the one from advance was bad all along... The resistance of the crankshaft position sensor is 1.371k Ω cold which is in specs for a good sensor.
