Old 01-18-2007, 09:58 AM   #1
sam07yaris
sam07yaris's Avatar
Drives: 07 yaris sedan (silver) STICK
Okay random photoshoot
Hey peeps, just giving u an update of my car and how she's doing. I decided to go out early in the morning to take pics so here they are : enjoy
mmm H.I.D. startup
looks like the sun is in my headlights
sam07yaris is offline   Reply With Quote
Old 01-18-2007, 12:23 PM   #2
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Looking sharp.
Did you paint your reflector bowl black? Flat/glossy? Is the parking lamp still there?
Old 01-18-2007, 01:42 PM   #3
sam07yaris
sam07yaris's Avatar
yep of course they work. I have been a member of hidplanet.com since it was hidforum.com. veteran here, lol so yeah i did this within 2 weeks of getting my car in july. I am doing another retro and trying it with TL w/ zkw lens. I'd rather wait though for aftermarket headlamps so i can do tsx and tl in one headlight
Old 01-18-2007, 04:54 PM   #4
Violin
Violin's Avatar
Huh?
Old 01-18-2007, 05:24 PM   #5
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Originally Posted by Violin View Post
Huh?
Maybe your question isn't clear enough!
PetersRedYaris is offline   Reply With Quote
Old 01-18-2007, 06:02 PM   #6
ChinoCharles
Drives: LB
If you can do a custom HID projector retrofit, I think you can understand that question.
Old 01-18-2007, 06:10 PM   #7
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
awwwww looks like the sedan is smiling, ooooooooooo
though dam mates of mine keeps sayin that my yaris looks like a hyundai smiling...bleh lol har har beep beep
Old 01-18-2007, 09:24 PM   #8
sam07yaris
sam07yaris's Avatar
lol exactly. By the pics, u can see its black and its flat so its not going to be shiny and absorb the light rather than reflect it. the pics show the signals are there. lol
Old 01-19-2007, 07:28 AM   #9
Violin
Violin's Avatar
Thanks for answering. Like I said, it looks great.
I wonder if you had the same trouble I do.
With the harness hooked up to the battery and the stock harness only powering a relay and halogen high beams, my high beam indicator no longer works. I tried putting a 100 ohm, 10 watt resistor across the low beam ground and power but that didn't fool the car. I'm thinking a higher wattage should work. Did you have this problem and find a solution?
Old 01-19-2007, 10:43 AM   #10
sam07yaris
sam07yaris's Avatar
so high beam doesn't work? no diode?
Old 01-19-2007, 11:56 AM   #11
Violin
Violin's Avatar
High beams work, low beams work - its the high beam indicator on the instrument panel that doesn't work.
It does work if I turn the lights on with the stalk in the high beam position, but once I switch them off, it's gone.
Its a problem on other vehicles, there's a thread on HIDPlanet right now. I was just wondering if you had the same problem with your sedan.
This is the wiring diagram I developed using drroy's "a circuit that wont allow HIDs to be flashed on/off" as a starting point.
Old 01-19-2007, 11:57 AM   #12
Violin
Violin's Avatar
There is a diode on the + leg of the parking lamp trigger.
Old 01-19-2007, 12:07 PM   #13
sam07yaris
sam07yaris's Avatar
hmmm
why on the leg of the parking lamp? shouldn't it be for the low to high
cuz diodes one way and i guess the lamp indicator needs feedback from the parking lamp and its blocking it
Old 01-19-2007, 12:43 PM   #14
Violin
Violin's Avatar
I added the relay on the parking lamp circuit because drroy's circuit was designed for a switching negative system where the power switches on and off with the headlamp switch. Our power (at least the liftback) is always on, even with the ignition off so the lights wouldn't turn off once relays 1 and 2 were triggered. The relay on the parking lamp circuit provides a way for the lights to switch off, because power to them switches off with the stalk.
There's no need for a diode on a switching ground circuit, inductive kick is not an issue. However, the parking lamp circuit is a switching positive circuit so I put a diode there to protect the circuitry. From what I can gather, the high beam indicator relies on a little power being passed through the headlight bulb - I just need the right value resistor to fool it.
I’m gathering this wasn’t an issue on yours?
Old 01-19-2007, 12:55 PM   #15
sam07yaris
sam07yaris's Avatar
no not at all bro.
Old 01-19-2007, 01:06 PM   #16
Violin
Violin's Avatar
Dang - lucky you.
I may end up just running a wire back to a blue LED somewhere on the dash but I'd much rather figure out how to get the factory indicator to work. Some European cars have a similar problem with a 'bulb out' indicator.
Old 01-19-2007, 01:20 PM   #17
sam07yaris
sam07yaris's Avatar
yeah definately. doesn't that suck ...
Random feature Kaotic Lazagna In Car Entertainment + Electronics (audio / video / alarm) 7 12-17-2006 05:24 PM
random nub posting question? Boonespeed Off-topic / Other Cars / Everything else Discussions 3 06-24-2006 06:15 PM
