10-21-2016, 04:29 AM | #1 |
Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
What tires are you guys running?
I am running hankook v2 concept 2 195/50/15 with TRD rims...its not the best set of tires but it does the job..👌👌👌👌👌
better than dunlop sp that came as stock...sliding everywhere and hella noisy...hope i saved up a little bit more and go for hankook RS3s..😣😣😣😣 Sent from my SM-J700F using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem Last edited by rabbito; 10-22-2016 at 03:09 AM. |
10-21-2016, 06:28 AM | #2 |
Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
I'm running Yokohama Avid Ascend's. They were put on the car new by the place that found my car for me.
They aren't the best wet weather tire but they have a big area for error when pushing it on the dry. They grip fairly well and last way longer then I would've thought (Have about 80,000km on them and still will get another 40k km) I'm usually fairly cautious on the wet roads as they can be unpredictable and let go sometimes as I found out the hard way last month. I've also just swapped the Yokohama Icegurad Ig20 winter tires from my Echo (no longer have it) to my winter alloys for my Vios. They are by far the best winter tire I have used. I'd probably stick with Yokohama in the future based on my experience, that said I haven't used any real high performance tires before.
No one ever wants to give a Yaris the point by... |
10-21-2016, 10:51 AM | #3 |
Michelin Pilot Sport A/S 3.
Super quiet. Love them. |
10-21-2016, 11:45 AM | #4 |
Small cars are a big deal
Drives: 2007 Yaris Liftback Join Date: Feb 2006
Yokohama S.Drives (summer)
Hankook Winter iPike (winter)
Subcompact Culture: The Small car blog |
10-21-2016, 12:09 PM | #5 |
Drives: Vitz RS Join Date: Feb 2009
Saulin Atrezzo zsr+
It's a very cheap tyre where I am that has grip compared to big brands in both the dry and wet. The front pair usually last me a year which includes daily driving and some autocross events. |
10-21-2016, 12:13 PM | #6 |
Drives: Yaris T2 Style 2016 Join Date: Jul 2016
Continental ContiPremiumContact 2 205/55 R16
Supplied with the car 2016 (europe) Only 900Klm so far so can't say much about them. The car runs *flat* and great (curves are tight) Looking to put winter tires on, Goodyear ULTRAGRIP 9 or Michellin ALPIN A4 Last edited by JMJahn; 10-21-2016 at 12:36 PM. |
10-21-2016, 02:19 PM | #7 |
Bridgestone RE-11a 195/50-15
Insane amount of wet weather grip and even more insane in the dry. I have roughly 25000km on them (over 3 years) and they still surprise me on how sticky they are. |
10-21-2016, 10:25 PM | #8 |
Drives: 2009 5-door, 5-speed Join Date: Sep 2011
When it is above 10°C: Nitto NT01 205/50r15 Best raw grip of any DOT tire I have driven.
When below: Kumho Ecsta 4X II. These are a good wet weather tire, and very responsive. I run these as my winter tires and do a winter autoX series on them. |
10-22-2016, 02:17 AM | #9 |
Drives: 2014 Yaris SE Join Date: Apr 2014
Bridgestone Turanza EL400-02 195/50r16. They're OEM on the SE Yaris. No complaints.
And shouldn't this thread be in the tire section? |
10-22-2016, 02:39 AM | #10 |
195 55 15 awesome tires perfect size. Sent from my SM-G920F using Tapatalk |
10-22-2016, 04:29 AM | #11 |
feed my pet
Michelin Pilot Sport 3 185/55/15 excellent grip in wet & dry!
Have driven them close to 42k km and threads are close to the markers so they are less grippy during wet conditions now. Would probably swap a new set at 45k and might try out Yokohamas instead. |
10-22-2016, 06:12 PM | #12 |
Drives: 2014 Yaris LE Join Date: May 2016
Kuhmo Ecsta directional rubbish tires I got with the rims I bought. marketed as an all season but complete rubbish in the wet. Decent in the dry though. Will buy a set of Yokohama S.drives later down the line.
Similar Threads | ||||
All terrain tires for cars? | Captain Slow | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 11-01-2013 11:05 PM |
Kumho Ecsta ASX Tires | MadMax | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 09-01-2013 04:32 PM |
tire noob question..what's the widest tire size can run on stock 15"s? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 12-06-2011 09:44 AM |
My 17" alloy rims and Kumho tires... will swap for your original wheels! | AutoWashCars | NY / NJ/ CT / PA | 5 | 02-08-2011 07:38 PM |
Selling winter tires and low profile floor jack with 2 stands | voodoo22 | Canada | 10 | 11-16-2009 09:12 PM |
