05-03-2016, 02:53 PM | #1 |
Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
wheel spacer Q
Anyone know how wide a spacer you can run on the front with stock lug nuts?
No one ever wants to give a Yaris the point by... |
05-03-2016, 03:38 PM | #2 |
Drives: 06 Polar White 5dr, 13 Soul 4u Join Date: Oct 2008
Safely about 3mm, 5mm at the absolute max.
05-03-2016, 04:00 PM | #3 |
hmm, I think 10mm would be ideal for same fitment to my rear. I don't really want to install the spacers with their own studs but it looks like that may be my only option.
I'll measure what I can fit, either 15mm or 25mm it will be since I want hub centric spacers
No one ever wants to give a Yaris the point by... Last edited by tmontague; 05-03-2016 at 04:26 PM. |
05-03-2016, 04:23 PM | #4 |
wheel spacer Q
My spacers are 10mm and they are hub centric. Based on my own fitment experience, 10mm in the rear gives you the same as the front.
Are you confusing lug nuts with studs. You are confusing me with your references to lug nuts. Sent from my iPhone using Tapatalk
05-03-2016, 04:28 PM | #5 |
^yup, thanks I edited it. It may be my slightly more negative camber in the front but I am much more flush in the rear then my front. I'll do some measurements tonight and post back here what the gap is.
05-03-2016, 04:35 PM | #6 |
The narrower rear track is why most spacer installs are done in the back only. To push the rear wheels outward to sit in the wheel wells comparable to the fronts.
Similar Threads | ||||
Wheel bearing / Outer TRE / Control Arm replacement howto | shepd | DIY / Maintenance / Service | 3 | 09-14-2015 04:20 PM |
Longer wheel studs for 5mm spacer? | Captain Slow | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 02-09-2013 10:35 PM |
FS: Sparco Wheel, Quick Release, Momo Spacer | Focus_Sh1ft | Items for Sale by private party | 18 | 04-27-2011 12:36 AM |
anyone knows if wheel spacer can be placed behind the hub??? | jackrabbit | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 07-02-2010 06:41 PM |
forged rims Vs. alloys | red-jdm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 07-23-2007 08:30 PM |
