Old 05-03-2016, 08:42 PM   #1
oij040173
Drives: Toyota Vitz 1999
Toyota Vitz built 1999 engine 1000cc
Hi guys,
I have a Toyota Vitz built in 1999 with a 1000cc engine.
My turn signal lights just failed to go on. The hazard lights are working.
I have been looking for a turn fuse but cannot locate it. Can anyone help me out please..
thanks,
Orlando
oij040173 is offline   Reply With Quote
Old 05-03-2016, 08:52 PM   #2
If the hazards work, but the turn signals do not, first check the 10A GAUGE fuse under the dash. The hazards work without the ignition and work off the 10A HAZ fuse, whereas the signals are ignition switched.
Old 05-03-2016, 10:45 PM   #3
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
I haven't checked the EWD but I know some systems use a separate flasher relay for the hazard lights vs. the regular turn signals.
Old 05-04-2016, 04:30 AM   #4
oij040173
10A gauge fuse is ok..also checked the multi switch on steering wheel, which is ok
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
Toyota axes Scion Kar98 Off-topic / Other Cars / Everything else Discussions 15 02-10-2016 12:01 PM
2009 Toyota Vitz/Yaris 1.3L hatchback Engine Heating Up VitzBD DIY / Maintenance / Service 8 09-22-2015 07:01 PM
Engine Delayed Start - Toyota 1NZ-FE 1.5L SL Runner General Yaris / Vitz Discussion 9 07-23-2011 03:13 PM
