10-22-2008, 08:36 PM | #37 | |
It's nice to have peak HP so close to redline, as it makes your point that much easier to work with. And, for most people (as well as the common point of view), shifting at redline would be best. Last edited by justjesus; 10-22-2008 at 09:04 PM. |
10-22-2008, 11:11 PM | #38 |
Drives: 09 Yaris hatch, 09 Z51 'Vette Join Date: Oct 2008
10-22-2008, 11:17 PM | #39 |
Drives: yaris rs Join Date: Jul 2007
so theres n problem on shifting almost all the time up to 6500 i have tach
10-23-2008, 08:43 AM | #40 | |
Drives: Corolla Join Date: May 2007
10-23-2008, 08:47 AM | #41 |
Drives: yw calls me douche and racist. Join Date: Aug 2007
10-23-2008, 08:50 AM | #42 | ||
Toyota didn't include a tach, to provide a super cheap ass Yaris. Want a tach? Get a S model. Still don't like it? Get a Fit. Earlier you had stated that you NEED a tach for a manual transmission, but now you're saying, Quote:
10-23-2008, 10:26 AM | #43 | |
No street driven engine should be shifted at redline "almost all the time." More revs equal more wear per mile. Racing engines are generally shifted at redline, but most of them have to be rebuilt on a regular basis. You can safely red-line the Yaris's engine (or any other street engine in good condition) on occasion (e.g. when merging into traffic, accelerating hard for the fun of it, etc.). Another user scanned and posted this. It shows recommended shift points for different driving conditions: http://www.yarisworld.com/forums/att...9&d=1224720740 |
10-23-2008, 01:31 PM | #44 |
OK, maybe a little off topic but this shifting pattern works best if you drive for the best fuel economy (so you do not need fast acceleration):
shift to 2nd at 10MPH shift to 3rd at 25 MPH shift to 4th at 35 MPH shift to 5th at 45 MPH |
10-23-2008, 01:35 PM | #45 | |
How do you know that 11 MPH, 24 MPH, 33 MPH and 46 MPH wouldn't be better, for example? |
10-23-2008, 01:57 PM | #46 |
The numbers I posted are based on many Yaris forum members experience (both with and without Scangauge II), unfortunately all those posts are lost now
10-23-2008, 04:27 PM | #47 | |
OMGWTFKITTYKATMEWMEWMEW
Drives: 2008 Yaris S Join Date: Oct 2008
Not including the tach on the lower models entices buyers to upgrade to the S model. I already wanted the S model, but once I heard the S model of the liftback was the only one that had the tach, I was sold. This is not a bait and switch, certain models only offer certain options. I'm sure there are plenty of people that wanted S-style seats in their base Yarises, but that's not an option. It's only available in the S model. You know what they offered, they don't hold a gun to your head telling you you need to buy the S. They tell you what you can get, then leave the decision up to you.
10-23-2008, 05:04 PM | #48 | |
10-23-2008, 05:56 PM | #49 |
10-24-2008, 07:40 PM | #50 | |
Drives: 2008 Yaris Sedan 5sp Join Date: Oct 2008
Interesting
06-06-2010, 11:17 PM | #51 |
PWN'ING NOOBS SINCE PONG
Drives: Yaris Join Date: Mar 2010
Decided to try 4th at 80-95 mph today...car did very well up hill for the whole duration (about 25 seconds...) no CAI or pulley...
06-07-2010, 07:36 PM | #52 |
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car Join Date: Oct 2008
The theoretically ideal revs at which to change up at to get max acceleration will vary depending on whether you are going up a hill, on a flat road, or going down a hill. It's all arbitrary.
06-07-2010, 09:19 PM | #53 |
Half a Bubble Off Plumb
Drives: 2009 Yaris Sedan Join Date: Mar 2009
If you're just looking for max revs, you can determine that yourself by revving up to the rev limiter in each gear. (On an off road course, of course.)
09-24-2010, 04:18 AM | #54 |
Drives: Yaris 1.3 AT,Mica Black Join Date: Sep 2010
''There's nothing wrong with revving these engines to redline - even on a relatively frequent basis. This engine is a DOHC/16 valve with variable valve timing. It's designed to rev.''
Hello there, I dont understand this? Are not all engines desinged to rev?wats special abt yaris,every other model also has vvt,n other car manu. gives it other names. eg honda - ivtec. How frequent is relatively frequent ? everyday 10 times is ok?Doesnt this wear out the engine,instead of the car lasting 200000 kms at peak efficenicy it might taper of at 150000,isnt that a concern? |
