04-14-2009, 06:42 AM | #1 |
Drives: stock Join Date: Apr 2009
Drum brake upgrade
Hi guys, Is it posible to convert Drum brake to Disc brake sistem?
04-14-2009, 07:10 AM | #2 |
Drives: Yaris YR Join Date: Oct 2008
If your talking about the Yaris Rear Drum Brakes, yes they can be converted into a Rear Disc brake system. You can buy the kit from Microimage Shop.
Link: http://shop.microimageonline.com/pro...=3&productId=7 Hope that helps.
Mods: 17x7 ANZ Tazer Wheels with 215/40/17 Marangoni Tyres | AFE Air Intake System | NST Short Shifter Kit | NST Shifter Cable Bushing Kit | NST 10% Underdrive Crank Pulley | Pedders Sports Springs | Custom 2inch Cat-Back Walker Muffler with 2.5inch Xforce Twin Stainless Steel Tip | RS Side Skirts | RS Euro Spoiler | YRX Front Lip Spoiler | TRD Style Front Grill | 12mm Rear Hub Spacers | Ultra Racing 23mm Rear Sway Bar |
04-14-2009, 04:05 PM | #3 |
Drives: '07 Yaris turbo, '11 Juke Join Date: Mar 2007
I did the rear disc brake conversion
http://www.cardomain.com/ride/3875996 |
04-14-2009, 04:20 PM | #4 |
Drives: Polar White Yaris HB Join Date: Dec 2008
How much of a difference did it make in your braking?
04-14-2009, 04:21 PM | #5 |
Another thought is instead of upgrading to discs is to do what we can to optimize the performance of the drums. Any thoughts???
04-14-2009, 04:51 PM | #6 |
Half a Bubble Off Plumb
Generally the rear brakes only account for about 30% of your braking power. Any changes you make need to be balanced with the front brakes or the rear wheels will lock up and lengthen your stopping distance. (Assuming you don't have ABS.)
Disc brakes are harder to use with a parking brake. Most cars with 4-wheel discs have an auxiliary parking brake drum. |
04-14-2009, 06:19 PM | #7 |
Drives: 09 yaris Join Date: Mar 2009
They do make calipers that have a lever that pushes the pads together for the parking break but it’s been used on few cars and still dose not have all the bugs worked out yet. I’m sure one of the manufactures will start using it soon and will be a new problem for the masses. At one point one manufacture will out way the issue of fewer parts to build into a car to the issue of fixing them under warranty…
09, 3 door lift back, auto. I live on the road with my wife. We travel as needed for our work and drive up to 4,500 miles in a bad week. |
04-14-2009, 06:51 PM | #8 |
Drives: 07 Yaris Turbo Join Date: May 2007
If you want to keep your drums but upgrade performance, order custom shoes (from me, of course) with CarboTech material to improve bite and grab, plus stainless lines and better fluid.
Otherwise, our rear disc conversion is very good. I've been using it on both track and street for several months with no problems.
04-14-2009, 07:49 PM | #9 |
If i park my car at the slope area will parking brake will the car roll down?
04-16-2009, 10:01 PM | #10 |
by the way is your rear disc brake ABS & EBD working? or just normal disc brake function?
04-17-2009, 03:28 PM | #11 |
Like discs, do drums need to be resurfaced if you are putting in new drum brake pads? The stainless lines sound like a good idea as well.
04-17-2009, 04:23 PM | #12 |
Drums typically are turned when the shoes are replaced. Lately my shop has found new Chinese disks and drums for most cars that cost little more than turning them, so they usually just get replaced with new ones.
04-19-2009, 03:34 AM | #13 |
Any other options for drum brake pads with great bit that are not dusty???
04-19-2009, 05:16 AM | #14 |
Dust is what you get when brake linings wear.
Similar Threads | ||||
DIY (sorta) - RunStop Rear disc brake conversion | eTiMaGo | DIY / Maintenance / Service | 17 | 07-02-2019 08:24 AM |
DIY INSTALL/REVIEW: Dezod X-Rated Yaris Brake Pads | ChinoCharles | DIY / Maintenance / Service | 40 | 10-13-2017 05:23 PM |
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside | YarisSedan | DIY / Maintenance / Service | 73 | 03-11-2017 06:05 PM |
Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
BIG(GER)TM BRAKE KIT | Vanderkitten | Performance Modifications | 23 | 01-04-2009 07:16 PM |
