Old 10-11-2006, 09:36 PM   #1
SDsurfrider
SDsurfrider's Avatar
Drives: 07 Sedan S
Auto Windows (all of them auto)?
Has anyone done this type of conversion? I don't know if it is possible to have the auto roll down function like some toyotas or lexus have.
SDsurfrider is offline   Reply With Quote
Old 10-11-2006, 10:33 PM   #2
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
Yes i believe its possible.....i have powered windows, though only my drivers side as that auto feature. Contact your local toyota dealer they might help ya.
But im 90% sure that u can impliment that to all the windows
Old 10-11-2006, 10:51 PM   #3
W.A.S.P
I love my Yaris!
W.A.S.P's Avatar
Drives: White Yaris Liftback 2 Dr. AT
There is auto roll down and roll up as well, I think that all you need is a relay that controls the regulator and stops the window when fully closed or open, not sure. Good luck!.. You can also see someone specialized in car alarms, they will be able to tell you.
W.A.S.P is offline   Reply With Quote
Old 04-11-2010, 04:05 AM   #4
djct_watt
Drives: 2010 NCP91 5spd
I would LOVE to have this upgrade!
Old 04-11-2010, 12:50 PM   #5
Mine only has auto for the driver's side. Passenger side would have to be retrofitted. Probably some electronics involved, not just a different switch - but that is just my guess.
Old 04-11-2010, 12:52 PM   #6
H3LlIoN
Drives: '09 Yarrrr hatch
I think there is some confusion in this thread...When you say auto down, do you mean the one touch roll down the window, or do you mean that the windows can be rolled down using the remote keyless entry fob?
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline   Reply With Quote
Old 04-13-2010, 06:33 PM   #7
severous01
there's a hall effect sensor in there and it counts how many revolutions tthe motor makes. so no, it's not just a switch.
but you could put a timed relay in there...and just set up the time for the relay to shut off when it reaches the max height. but then again you'd have to have steady voltage and amperage to the relay or timer...too much of a pita for me to do.
Old 04-13-2010, 08:42 PM   #8
The easiest way is to use a DEI 530T for auto up/down on both windows (or for a 5 door or sedan, you use a second 530T for the back windows).
I put together a DIY a while back on wiring it up:
http://www.yarisworld.com/forums/sho...3&postcount=39
