Old 10-17-2014, 09:50 AM   #1
BoostedTRD
Drives: 09 Yaris Hatchback
Aftermarket Cams
Who makes aftermarket cams for 09 Yaris? I've been through a few websites but still cant find a company who makes them.
BoostedTRD is offline   Reply With Quote
Old 10-17-2014, 10:18 AM   #2
Jun
Old 10-17-2014, 11:22 AM   #3
Jun is overpriced, but I can get them. Much easier to do a regrind locally.
Old 10-17-2014, 02:16 PM   #4
BoostedTRD
How much will that be? Will these cams be perfect for forced induction?
Old 10-17-2014, 03:50 PM   #5
kou
Drives: 08 lb
How much power do you want to make? stock head should be good for 250hp. An lsd would be a better investment.
Old 10-17-2014, 04:01 PM   #6
BoostedTRD
I want to be in the 300hp I will be also building the bottom end, CP pistons and either crower or carrillo rods. Cometic Headgasket and APR Bolts. Stage 5 racing clutch
My kit has a T28 but I may want to go with a T3 if it fits
Old 10-17-2014, 04:36 PM   #7
kou
Drives: 08 lb
Ptuning.com can make you a nice bottom end if that's what you want. The sleeves on the 1nzfe are thick the motor will hold 300hp as they are. The head flows very well as it is maybe a little port and polish. It's all your own choice just some advice also you have to factor if you get cams to raise the redline power is coming in later as will boost unless you get a smaller turbo. I personally like to keep as much torque down low as possible because I am never really going past 100mph and 10-11psi at 1/3 throttle in any gear makes for some fun times. sorry for the rant.
Old 10-19-2014, 07:57 AM   #8
GOLIATH'S
Drives: 2008's Black Yaris RS
I heard Gude camshaft is good for 1nz....anyone use?
GOLIATH'S is offline   Reply With Quote
Old 10-22-2014, 08:42 AM   #9
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Gude's reputation is questionalble.. There was a big thread on that one
-Derrick-
Old 10-22-2014, 11:29 AM   #10
That's probably true, and it's also pretty easy to get a port and polish done.
That's all I did to my head and made a reliable 350 whp with stock cams, stock valves, just valve springs.
Ptuning does great work; good, professional shop.
Can an aftermarket part void my car warranty? KCALB SIRAY General Yaris / Vitz Discussion 7 05-26-2022 10:47 AM
OEM vs Aftermarket Water Pump? antone DIY / Maintenance / Service 0 10-23-2012 12:25 PM
Best Aftermarket Headlights MadMax Cosmetic Modifications (Exterior/Interior) 3 06-04-2009 06:50 PM
Aftermarket Parts Interest? Fluid Motorsports General Yaris / Vitz Discussion 27 11-09-2008 12:00 PM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 01:13 PM
