07-17-2013, 10:00 PM | #1 |
Drives: 06 Yaris HB CE Join Date: Aug 2009
Any way to add traction control?
I realize some yaris have TRAC built in, and some don't. I am wondering since it's the same ecm, is it possible to add traction control?
thanks |
07-17-2013, 10:44 PM | #2 |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
The ECM and ABS ECU are different for the ones that have it. If you have ABS, you could add it by replacing those.
07-17-2013, 11:01 PM | #3 |
Oh.. it sounds it will be too expensive. I do have ABS.
I realized my car has no traction control when I could skid around in a gravel field with the front wheel spinning all over the place :p |
07-23-2013, 02:34 AM | #4 |
Modded Moderator
Price it on ebay. Plenty of salvage yards selling them (although I didn't look into the cost.)
I would have never thought to ask such a question. Guess I assumed it was an added mechanical feature, so I learned something new about the Yaris today. Doesn't affect me as my '07 does not have ABS. |
07-24-2013, 11:08 AM | #5 |
Bronze bombshell yaris
Drives: 09 Yaris HB 3door Join Date: Sep 2010
I have an 09, any way to know if I have ABS or traction control?
Now I drive a CARMINE RED METALLIC 09 Yaris 3-door!! I'm Back!!! WooHoo!! Mods done so far: Tinted windows, Viper 211HV Remote Keyless Entry, Atoto Android headunit, backup camera, steering wheel controls Before it was totaled I drove a 2007 Black Sand Pearl 3 Door Lift-Back M/T with 49k miles. Stock Everything except for black tint, all red badges, red dash, and stealth garage door opener. Ultra-Gauge mounted on steering wheel. A1 Electric MES Central Locks and Avital 3100 Alarm system. |
07-24-2013, 11:28 AM | #6 |
All US 09s have ABS. Traction control wasn't added until 2010.
07-24-2013, 01:19 PM | #7 |
2ZR swap. DO IT! Ask how!
You would need the yaw (rotation around the vertical axis) rate sensor: http://www.villagetoyotaparts.com/pr...918052050.html
Looks like you need the steering angle sensor, too: http://www.villagetoyotaparts.com/pr...924552030.html No idea if the wire harness on the 07-09 has a connector for those... |
07-24-2013, 03:16 PM | #8 | |
That's right - The Yaw rate sensor and steering angle sensor are new pieces as well for the VSC.
07-24-2013, 04:49 PM | #9 |
Wow, now that would be some DIY... LOL ;)
Similar Threads | ||||
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 467 | 10-18-2022 10:20 AM |
Disabling Traction Control | Aarron_M | DIY / Maintenance / Service | 7 | 02-21-2013 08:57 AM |
Does traction control help in snow ? | vector9mm | General Yaris / Vitz Discussion | 23 | 01-25-2012 11:41 AM |
NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 06:38 PM |
