07-04-2015, 09:08 PM | #109 |
07-05-2015, 02:49 PM | #110 |
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
Update: Ok. Found the template for the flange that can connect the 1zz intake manifold runners to the 1NZ engine block intake ports.
http://www.yarisworld.com/forums/sho...24&postcount=7 Beautiful piece of work. Thanks Cranky! Next, gotta find some info on the bolt pattern adaptor for the throttle body...
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog |
07-05-2015, 07:44 PM | #111 | |
2ZR swap. DO IT! Ask how!
Sent from my XT1031 using Tapatalk |
08-12-2015, 11:01 AM | #112 |
Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
I'm thinking about doing this mod next spring to go along with my intake and header.
Rock auto only has the 031 TB listed. Will this one still work as long as you swap the chip from th stock TB? Does anyone know an online source to find the 030 TB? I will have to keep running the coolant to the TB due to where I live. Has anyone been able to run th stock hoses by just swapping them a previously stated? |
08-12-2015, 11:12 AM | #113 |
Drives: 12 LE 5d HB 1nz-fe Automatic Join Date: Oct 2014
About the hoses it's not hard to get a new piece of hose got one from auto zone cut to the length I needed for like 4 dollars
I couldn't find anywhere online that sold the TB but searched for toyota recyclers online near me and found quite a few that had them and cheaper then getting it though the auto parts stores Sent from my SM-G386T using Tapatalk |
08-12-2015, 11:36 AM | #114 |
Thanks for the heads up. I'll likely buy extra hose just in case.
Did you give th recyclers the parts # for the TB and ask I they had it? |
08-12-2015, 12:14 PM | #115 |
I just asked for the year and model that you want the TB from mine was from a 2006 corolla
08-12-2015, 01:00 PM | #116 |
Drives: 2009 Yaris Join Date: Jan 2014
Found my 1zz TB on ebay one year ago and it was rebuilt new condition for $100 about. Same this year for my 1zz intake manifold and $40
05-19-2016, 01:54 PM | #117 |
Drives: 2009 Yaris HB Join Date: Jan 2011
Hello Black_griffin6,
Quick question, do you happen to have a part number for that 1zz throttle body? I'm looking to install into my '09 Yaris hatchback, to complement my other mods (K&N cold air intake, Blitz supercharger, DC header, Magnaflow catalytic converter, and TRD exhaust). Thanks! |
05-24-2016, 01:17 PM | #118 | |
Drives: 09 Meteoric Metallic 3 door HB Join Date: Jul 2010
There's actually one for sale on ebay right here. http://www.ebay.com/itm/2005-Toyota-...1XLsSG&vxp=mtr |
05-24-2016, 01:22 PM | #119 |
2010EGGHATCH
Drives: White 2010 Yaris Hatch Join Date: Apr 2016
$73 shit I'd check a local junk yard first I picked mine up from a Pull A Part for $49
Sent from my SM-G920T using Tapatalk
IG: 2010EGGHATCH |
05-24-2016, 01:52 PM | #120 |
05-24-2016, 02:04 PM | #121 |
2010EGGHATCH
Ah ok my local Pull A Part is full of Corollas right now lol
IG: 2010EGGHATCH |
05-24-2016, 02:47 PM | #122 | |
05-24-2016, 04:52 PM | #123 | |
I might have did away with the stock TB gasket...this was a few years ago, I don't recall exactly. XD |
05-29-2016, 05:02 PM | #124 |
Drives: 2006 Yaris RS 3-Door Join Date: Feb 2016
05-30-2016, 01:44 PM | #125 | |
Drives: 2007 yaris 3 door Join Date: Sep 2015
you should just do the chip swap and adjust the COLD idle screw and it works great. the chip swap is super-doper pooper-scooper easy. you just drill out the rivets on both TBs and swap the back covers. install bolts and nuts to secure. no wiring or soldering. it's 99.99999% impossible to do anything wrong. go to a local junkyard or pull-and-save or whatever to get the best price, and you can have one tomorrow! here's mine. had it for 3 months now. LOVE IT!!! http://www.yarisworld.com/forums/album.php?albumid=1179 Last edited by SirDigby; 05-30-2016 at 01:58 PM. |
06-23-2016, 10:10 PM | #126 |
Drives: 2015 Toyota Vios Join Date: Jun 2016
is this plug and play?
Thread Tools | |
Display Modes | |
Similar Threads | ||||
TPS reading at WOT with 1ZZ throttle body? | 4/20 NEVER FORGET | Performance Modifications | 14 | 07-02-2023 04:20 AM |
Installed the 1zz throttle body - | AlexNet0 | DIY / Maintenance / Service | 135 | 08-01-2014 07:57 AM |
FS: 1ZZ throttle body and Fujita intake | mrbond | Items for Sale by private party | 25 | 09-08-2009 10:21 PM |
Intake to match the 1ZZ throttle body | fuji | DIY / Maintenance / Service | 2 | 06-17-2009 10:02 PM |
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers | m911gt | Items for Sale by private party | 6 | 04-25-2009 08:52 PM |
