Old 05-24-2018, 04:47 PM   #1
Pinchlite
Drives: 2007 yaris HB
Wheel spacer question...
I currently have 10mm wheel spacers in the back with extended studs(10mm longer then stock)
I want to swap the back for 15mm and use the 10 up front.
So the basic question is 10mm longer then stock studs long enough for 15mm spacers.Not sure how much longer the studs that come with the 15mm spacers will be.Just dont really want to have to remove the rear studs again.
P.S 10 mm longer then stock better be long enough as I dont think I can fit longer then the current I have on the back.It was a tight fit.
Old 05-24-2018, 10:41 PM   #2
tmontague
tmontague's Avatar
Yes, 5mm is as large as you would safely want to go outside of getting the studs to match the spacer thickness.
Ie: either 5mm spacer w/ oe size studs of 10mm extra long studs with 15mm spacers
Old 05-25-2018, 05:06 AM   #3
Pinchlite
I already have extended studs in the back(10mm larger then stock)With 10 mm spacers.
I want to take the 10 mm spacers and swap to the front and replace the back with 15mm.
From what you say 10 mm longer studs is suffecient for 15mm spacers aswell.
If this is the case I can leave the 10mm longer studs in the back and just use the longer studs that will come with the 15mm spacers for the front.
Perhaps the 15mm and the 10mm spacers come with the same length extended studs?
Front wheel well plastic question? Pinchlite Cosmetic Modifications (Exterior/Interior) 19 03-28-2017 08:10 PM
Wheel bearing / Outer TRE / Control Arm replacement howto shepd DIY / Maintenance / Service 3 09-14-2015 04:20 PM
Wheel Well Question gwasabi Cosmetic Modifications (Exterior/Interior) 3 04-15-2009 12:09 PM
Wheel well Question Repost gwasabi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 04-13-2009 07:17 PM
Wheel Care Question - Polish coming off? Ran Kizama Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 04-25-2007 05:49 PM
