Old 01-30-2009, 05:17 PM   #19
cm07yaris
Drives: 2007 Toyota Yaris Blazing Blue
Send a message via AIM to cm07yaris
Thanks guys, I'll take another look.
cm07yaris is offline   Reply With Quote
Old 01-30-2009, 08:00 PM   #20
cm07yaris
I believe I found my problem. The 120 Alt. fuse within the fuselink on the positive battery terminal was fried...we'll find out on Tuesday when the replacement arrives. Thanks again for all the replies!
Old 01-30-2009, 08:22 PM   #21
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
***COUGH***
Originally Posted by SHROOMSTER
....remove the negative and then the positive look at the big glob of crap on the positive battery wire.....make sure both the fuses are ok....the one is the alternator fuse won't let the car turn over the other is the starter fuse IIRC.... both are like 50A or something....
*COUGH*
Old 01-30-2009, 08:44 PM   #22
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
***COUGH*** *COUGH*
Are you chokeing on something Shroo, do you need help tooooo
well done
Old 01-30-2009, 11:51 PM   #23
Shroomster
Shroomster's Avatar
lol nah...I should've written the entire thing out...the alt fuse because its so big will sometimes melt itself to a point where it will still arc power.... but the pcm senses a drop and cuts all outlying power accessories....
Old 01-31-2009, 01:45 AM   #24
cm07yaris
Hehe, I guess "big glob of crap" doesn't mean much to me! Not quite the type of fuse I was expecting to see... I believe its some sort of fuselink.
Old 01-31-2009, 03:32 AM   #25
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
I'm about to install the underdrive pulley... any thing I should do to prevent this?
Old 01-31-2009, 04:39 AM   #26
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
be careful not to short out battery.
but you should have no worries unless you are doing all 3 pullies.
Old 01-31-2009, 11:30 AM   #27
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
Damn Casey, I just found this thread. I'm glad you located the source of the problem!
Wanted: Forced Induction
Old 01-31-2009, 10:02 PM   #28
cm07yaris
Thanks man, I'll find out for sure if this is the problem on Tuesday. I'm 99% sure it is...
Old 02-05-2009, 12:22 AM   #29
cm07yaris
Up and running again, only $12.95 later!
Old 02-05-2009, 01:04 AM   #30
Shroomster
Shroomster's Avatar
12.95 for the fuse?
Old 02-05-2009, 10:02 PM   #31
cm07yaris
12.95 for the fuse?
It's a fuseable link...have a look sometime. Take off the red plastic cover on the positive battery terminal.
Old 02-05-2009, 10:30 PM   #32
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
Whew! Glad to hear it was a cheap fix!
Old 02-05-2009, 10:50 PM   #33
Shroomster
Shroomster's Avatar
lol...I'm the one that told you to look there...anyways glad to hear you're back up and running again!
Old 01-15-2019, 12:20 AM   #34
xxcanuckxx
Drives: 2015 SE HB
Same problem here...
Its 2019, is anyone still on this forum? Anyone following this thread?
If I understand correctly, I am looking for something under the big plastic protector on the positive wire that runs to the battery? This seems to be the same problems I have been having...
2007 3dr RS 5spd, 380,000km...
xxcanuckxx is offline   Reply With Quote
Old 01-15-2019, 08:23 AM   #35
The glass rectangle you see here is the fusible link.
Old 01-16-2019, 10:30 AM   #36
xxcanuckxx
Drives: 2015 SE HB
Thank you WeeYari! Much appreciated!
