07-29-2015, 07:54 PM | #1 |
Drives: 07 yaris sedan Join Date: Apr 2009
Interior blower motor wiring. Which one is positive?
There are two wires leading into the blower fan. I need to test them to see if power is getting to them....don't want to get them wrong. Which is the positive wire. Blue or black?
07-29-2015, 08:54 PM | #2 |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
Black is positive.
07-29-2015, 09:18 PM | #3 |
Thanks buddy. I think I've got a melted connector. In the meantime...WHY THE F WOULD THEY MAKE THE BLACK ONE THE POSITIVE????!!! Black wires where I come from mean negative!
07-29-2015, 09:40 PM | #4 |
Not for Toyota. White with a black stripe is negative. Almost all black wires on modern Toyotas are positive.
07-31-2015, 01:30 AM | #5 |
It was a melted connector plug. I cut the plug and crimped on a couple insulated female connectors. Done. Total cost 1.30. Thanks to you all!
Similar Threads | ||||
Positive Battery Terminal | alex33016 | DIY / Maintenance / Service | 5 | 02-08-2015 02:17 PM |
Positive words for the Curt Hitch | Tifford | DIY / Maintenance / Service | 5 | 06-05-2013 10:42 PM |
Where to get ring connector for positive battery terminal? | IsLNdbOi | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 11-13-2008 11:44 PM |
LED positive negative question ASAP | Sway84 | Cosmetic Modifications (Exterior/Interior) | 2 | 06-21-2007 08:39 AM |
Yaris Positive or Negative grounding system? | marcus | General Yaris / Vitz Discussion | 2 | 04-20-2007 10:25 PM |
