Old 03-25-2017, 09:07 PM   #1
Yarisblu
Drives: Blue hatchback 2 door 2008 yar
Stroker 2nz with 1nz pistons?
Hey guys, i`ve been wondering if i could make more displacement out of my 1.3 by porting and changing to 1nz 1.5 pistons. Does anybody know? thanks
Yarisblu is offline   Reply With Quote
Old 03-25-2017, 09:24 PM   #2
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
It would be easier to do a complete engine swap. The 2NZ and 1NZ have the same cylinder bore, with the 1NZ having a longer stroke.
I think you will find the 1NZ block is a bit taller to accomodate the longer stroke, so you would need custom shortened conrods to fit a 1NZ crank into the 2NZ block without the pistons hitting the head.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 03-26-2017, 04:09 PM   #3
Yarisblu
Hey dude!! my plan would be just to change the pistons heads, without crank nor conrods.
But because you`re telling me that the bore is the same i guess the 1nz has more displacement only because of the longer stroke alone?
So to do something like im planning I would have to replace head or block, conrods, crank, etc.?
Old 03-27-2017, 02:24 AM   #4
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Changing the pistons won't change the displacement. I don't know if the 1NZ and 2NZ use the same pistons.
There are a number of people on the forum who have installed 1NZ-FXE pistons from the Prius into the 1NZ to raise the compression. Perhaps someone can check the part numbers for 1NZ and 2NZ pistons..
Old 05-03-2017, 08:58 AM   #5
tmontague
tmontague's Avatar
^what he said
Old 05-23-2017, 10:30 PM   #6
Yarisblu
Hey guys so there are no prius in my country so to get 1nz-fxe pistons would be too hard.
But there are yaris belta 1.5 1nz-fe... How can i do to bump my 1.3 2nz-fe to the 1nz-fe displacement?
Does anybody know? Block and crank only? Rods, head?
Thanks!
stroker
Performance Pistons? rabbito Performance Modifications 3 09-21-2016 06:08 AM
Prius Piston swap in 1NZ (update pls) rabbito Performance Modifications 2 06-12-2016 10:18 PM
2nz pistons in 1nz salmanghiyas Performance Modifications 1 11-15-2014 01:30 PM
1NZ / 2NZ Transmission Compatibility & Aftermarket 2NZ Rods jtw11 Performance Modifications 8 09-03-2013 01:49 PM
Con rods and Pistons leinadeb Performance Modifications 4 05-23-2010 07:30 PM
