Old 11-06-2015, 05:13 AM   #1
ironclaw
Drives: Yaris (06)
After Market Horn - Hood Connectors?
Hi Everyone,
I wish to fit an aftermarket horn to my 2006 Yaris. I'm confident in electronics but want to check if there is an easily accessible connection in the hood / engine bay. I would rather install so that the stock horn can be re-connected at at will, so wire cutting / splicing I'd like to avoid.
Does the stock horn have a wiring loom / connector block that is easily accessible? I just need a 12V+ to switch a relay, the rest I can wire myself.
Many Thanks!
ironclaw is offline   Reply With Quote
Old 11-06-2015, 06:01 AM   #2
There are a couple of threads on here with details on installing aftermarket horns. The horn itself has a very small feed wire, so ideally you do want to wire in a relay to feed the new horn. There is a Junction connector in the under-hood fuse box, which is the best place to grab the horn feed, to use it to feed the coil of a relay.
My horn install... Goose DIY / Maintenance / Service 7 01-29-2016 04:10 PM
C-One Replica Hood. Lets Fix this sucker! TinyGiant Cosmetic Modifications (Exterior/Interior) 56 11-09-2009 11:31 PM
Micro Image Hood Design Contest cali yaris Micro Image 209 10-04-2009 02:49 AM
Installed hood deflector, in-channel vent visors and hood seal. IsLNdbOi Cosmetic Modifications (Exterior/Interior) 16 12-20-2008 08:36 AM
Before you buy . . . check that hood! woof General Yaris / Vitz Discussion 4 12-02-2006 05:14 PM
