Old 07-09-2017, 01:13 PM   #1
bambam28
Drives: Yaris Hatchback 2012 SE
Yaris starting noise
Hello everyone, my yaris sedan 2010 with automatic transmission has the automatic starting, and 3 days ago once it started, the starter didn't shut off and there was a grinding noise for another second, and it sounds horrible, well you guys can imagine. I did some reasearch and apparently the relay is what I should be looking at, anybody want to confirm this or has had the same problem, it only happens in the morning and only with engine completely cold, thank you in advance
bambam28 is offline   Reply With Quote
Old 07-11-2017, 01:24 AM   #2
bambam28
Bump
Old 07-17-2017, 08:06 PM   #3
bambam28
Anybody :( ?
Old 07-18-2017, 10:59 PM   #4
Ranger SVO
Drives: 2010 Yaris
What do you mean by automatic starting?
The moving power of mathematical invention is not reasoning but imagination.
Augustus de Morgan
Truth does not change because it is, or is not, believed by a majority of the people.
Giordano Bruno
Ranger SVO is offline   Reply With Quote
Old 07-20-2017, 01:10 AM   #5
bambam28
Hey thanks for the reply, automatic starting meaning that instead of holding the key forward till the car starts, you just have to move it to start and let it go and the car cranks by itself for however long it takes to start.
Old 07-20-2017, 02:16 PM   #6
Ranger SVO
Drives: 2010 Yaris
OK Thanks
The only starter relay that I am aware of is the solenoid on the starter itself. The only way I can think of to diagnose the problem is with a volt meter.
Hook it to the crank wire, start the car. The voltage should go to 12 volts and drop the second the car starts. If the starter is still working after the voltage goes away, solenoid problem.
Augustus de Morgan
Giordano Bruno
Old 07-23-2017, 01:37 AM   #7
bambam28
Thanks for the reply, there is a relay on the engine fuse box, i did the continuity check and has continuity, but have not done the click test with a battery. I will try to do the starter solenoid test, and keep you guys up to date :)
Old 08-03-2017, 12:39 PM   #8
bambam28
Hello guys, just wanted to come by and tell you guys that it was not the starter that was bad it was the solenoid, toyota replaced this starter with a new part number, part number 28100-21021 was replaced with 28100-21022, hope I can help somebody out there
Need help finding the Japanese part number for the TRD Sway Bar (PTR11-52071) chalked Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 01-26-2013 03:29 PM
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW VitzBoy General Yaris / Vitz Discussion 5 09-05-2010 08:53 PM
NEED HELP - Yaris suspension part Trish General Yaris / Vitz Discussion 11 11-07-2009 04:01 PM
Yaris Pricing Question minervamoon New YARIS Purchase Forum 34 06-21-2009 05:26 PM
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
