Old 02-26-2017, 11:08 AM   #1
SirDigby
Drives: 2007 yaris 3 door
Better Lower Grill for Cheap!
I really do not like the "X's" lower grill. looks cheesy and does not have good coverage. I purchased a grill from the dealership (@$15) and a gutter guard from home depot for $4. flattened gutter guard.
then I trimmed mesh to fit grill and cut out space for bumper clips:
then removed plastic X's and trimmed mesh to fit properly:
then I used DEI SS zip ties to secure in place. I used these zips because of their durability and their super thin profile. (about 1/2mm)
then a some final coats of paint and clear coat:
I will post some pictures of it installed when it gets warmer out
Old 02-26-2017, 12:10 PM   #2
scratchpaddy
Hubcap Enthusiast
scratchpaddy's Avatar
Drives: '09 3-door 5-speed
That looks really nice! I'm eager to see what it looks like on the car.
scratchpaddy is offline   Reply With Quote
Old 02-26-2017, 12:23 PM   #3
SirDigby
it will go on soon. I also painted the upper grill the same gloss black, and plan to do the foglight/duct covers and steel wheels with the same black. we'll see if next weekend is 70 or 20. it might be in the exhaust shop, then it would be a week later. well, I do need to do the rear end work too, so it might be even a few weeks after that. should be in before April... :)
Old 02-26-2017, 02:05 PM   #4
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
+1
On Instagram
On Wheelwell
Old 02-26-2017, 04:14 PM   #5
kimona
kimona's Avatar
Drives: 2014 White VITZ
You did a great job! I'm waiting to see it on the car.
Old 05-20-2017, 10:30 PM   #6
SirDigby
sorry i didn't post pictures sooner!
old grill:
new grill:
i like how it looks!
Old 05-21-2017, 09:45 AM   #7
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Nice. You could even cut out the "T" grill.
Old 05-21-2017, 01:11 PM   #8
SirDigby
i was going to do that, but since the +09 has a black grill, and most other cars have black grills, the white bumper grill added a slight level of uniqueness...
Old 08-03-2017, 03:27 AM   #9
Majestic
Majestic's Avatar
Drives: 2007 toyota yaris T3 a/c 5dr
cutting out the T grille would make the bumper to be weak?
Majestic is offline   Reply With Quote
Old 08-03-2017, 11:01 AM   #10
kimona
kimona's Avatar
Looks very good.
Old 08-03-2017, 11:14 AM   #11
ern-diz
ern-diz's Avatar
Looks very good.
+1
On Instagram
On Wheelwell
Old 08-06-2017, 01:44 AM   #12
SirDigby
no. the opening is not large enough to cause flex. if you were careful and did not cut the tabs, the grill would add support.
Old 08-06-2017, 08:38 PM   #13
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Wow. I used gutter gaurd in the grille of my 94 caravan 15 years ago to achieve that grillecraft look
Glad its still being done
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 08-07-2017, 11:58 PM   #14
SirDigby
yep. $3.95 and $12 for the SS zip ties. ($15 for a new grill so i could build it without removing first, in case i damage or something)
grill, gutter guard, lower grill, mesh
07-08 RS lower Bumper grill? SirDigby Cosmetic Modifications (Exterior/Interior) 13 09-02-2016 08:07 PM
DIY - Adding Front Lower Grill Mesh 33OH Cosmetic Modifications (Exterior/Interior) 24 08-13-2013 03:06 PM
Xa and XB lower grill dimensions ? bladesmith6 Cosmetic Modifications (Exterior/Interior) 6 05-23-2010 03:20 PM
Yaris Lower Grill / Radiator Grill Reeves360 Cosmetic Modifications (Exterior/Interior) 9 11-16-2009 08:45 PM
Lower Grill Replacement Idea (feeler) counterfiend Cosmetic Modifications (Exterior/Interior) 7 09-24-2009 08:40 PM
