Old 03-20-2017, 10:48 AM   #1
miiser
miiser's Avatar
Drives: yaris 2009
K&N air filter noticeable difference?
Hi,
I am thinking of replacing my stock air filter to a higher flow K&N filter.
Are there any advantages over the stock one?
Any noticeable difference and any reasons to do that?
My engine is 1.3 101hp all stock.
Link for the filter:
https://www.amazon.com/gp/aw/d/B000N...VeL&ref=plSrch
miiser is offline   Reply With Quote
Old 03-20-2017, 11:14 AM   #2
tmontague
2zr-fe dream team
tmontague's Avatar
Drives: 08 Vios M/T, 05 4wd Vibe
With just the filter by itself and no other flow mods (exhaust, intake manifold, header etc) it won't make a noticeable difference in performance. The sound may change though.
Keep in mind I haven't installed that filter, but I'm basing my comments off of mine and others experience with a short ram intake.
2zr swapped Vios, oil catch can, TRD rear sway bar, MI lowering springs, In cabin+under hood SSK, TRD shift knob, HID projector/Halo lights, 10mm rear axle spacers, custom header back exhaust, Front splitter, Sickspeed dual horns, Tokiko Blue's in rear, triple gauges, Whiteline bushings, Sparco pedal covers, Viper Keyless entry
Old 03-20-2017, 04:16 PM   #3
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Id stick with a stock filter. Its cotton and flows well for the given size.
Id remove the carbon trap in the airlid you will see more of a difference in that
-Greg...the Exhaust Freak.
-'10 PW sedan 106whp/110wtq, full exhaust, suspension goodies
-'82 Malibu, 1uzfe swap
-'83 Malibu, lowrider
Old 03-21-2017, 02:49 AM   #4
bronsin
bronsin's Avatar
If you go KN make damn sure you don't over oil it. That will oil up the wires in the MAF sensor big time!
May happen no matter how you oil it!
Old 03-21-2017, 08:05 AM   #5
miiser
miiser's Avatar
Drives: yaris 2009
So maybe I shouldn't do it?
Old 03-21-2017, 09:15 AM   #6
Not really. Given the negligible performance gains, coupled with the cost/hassle of cleaning/oiling the thing, not worth it imo. May want to look into something like an AFE washable dry filter, or just stick with disposables.
Old 03-21-2017, 02:40 PM   #7
bronsin
bronsin's Avatar
My vote is the OEM filter from Toyota! Im 60 and in all my carowning life, its the best one Ive seen.
Old 03-21-2017, 05:59 PM   #8
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Correct air filter not fitting right in sedan? JerseyJeff84 DIY / Maintenance / Service 13 09-28-2011 02:27 PM
AEM Filter + K&N Cleaner = WTH Marie DIY / Maintenance / Service 5 05-25-2011 11:29 PM
Liftback Air Conditioning (Cabin) Filter info Snappy DIY / Maintenance / Service 24 10-01-2010 06:36 PM
Stealership faked a filthy cabin air filter kenora DIY / Maintenance / Service 14 09-15-2009 09:00 PM
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
