Old 03-09-2017, 01:57 AM   #1
frank2005
Drives: Toyota Echo RS 2005
STP Injector Cleaner
waste of money ?
This detergent really cleans injectors?
On the recommended bottle every 10,000km or 6,000 miles
Help keep clean injector
* is it necessary
frank2005 is offline   Reply With Quote
Old 03-09-2017, 07:32 AM   #2
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
Even Toyota has a product branded and its 350ml in european market.
Its preventative maintenance . Wont do miracles and wont hurt either.
I use it every time I get a chance. :)
ncp13 is offline   Reply With Quote
Old 03-09-2017, 11:00 AM   #3
chief ten bears
chief ten bears's Avatar
you want a product with PEA, polyetheramine. that's what does the actual cleaning. gumout, techron, and even a motomaster fuel system cleaner in canada, all have pea in them.
chief ten bears is offline   Reply With Quote
Old 03-09-2017, 11:30 AM   #4
bronsin
bronsin's Avatar
Originally Posted by frank2005 View Post
waste of money ?
* is it necessary
No such requirement in the owners manual under Service.
Every 6000 miles? You gotta be kidding me!
Never had a problem with gunked up injectors and Im 60 years old and keep my cars at least 100k miles.
But I also use brand name gas.
Old 03-09-2017, 07:16 PM   #5
B.B._07
Drives: 07 5dr
waste of money ?
* is it necessary
Most mechanics that work on a lot of modern Toyota's and Honda's will tell you it's not needed and more a waste of money. If your car is properly maintained you won't need. When I bought the Yaris I got some STP fuel injector cleaner in one of those car care bundles from Walmart and I must say I didn't notice any actual difference. I think it's only worth it on old vehicles with lots of miles that have much simpler and less efficient fuel injection and emission systems.
Old 03-09-2017, 08:18 PM   #6
SirDigby
Drives: 2007 yaris 3 door
I like BG products. I would only use 44k or supercharge II
Old 03-10-2017, 09:08 AM   #7
Just use top tier gas and none of that cheap stuff that will cause clogged injectors and carbon build up on the valves.
Old 12-29-2019, 12:47 AM   #8
rayfloyd170
Drives: Yaris 2016 1.3 Manual
better to clean the injectors physically.
i decided to remove and clean it when there was minor o-ring leak that turned to be a major fuel leak.
Last edited by rayfloyd170; 09-19-2021 at 04:12 AM. Reason: already cleaned my injectors physically
rayfloyd170 is offline   Reply With Quote
Old 08-30-2021, 03:42 PM   #9
mik36
Drives: VERSO S
Clean the injectors via fuel line method and then u can see the difference.
These additives makes very little difference.
suggested by Ex Toyota Engr.
mik36 is offline   Reply With Quote
Do stp cleaners work? gabriel2012 Fuel Economy Forum 14 08-27-2011 08:10 AM
