Old 05-03-2017, 06:36 AM   #1
toyo-ka
Drives: Yaris Excel Hybrid
Fusebox location
Hi! I need help finding the fusebox. Can anyone give me instructions on how to find it on 64reg Yaris Hybrid Excel please? I need to check if the fuse for my cigarette lighter output is blown. Thank you!
toyo-ka is offline   Reply With Quote
Old 05-04-2017, 05:15 AM   #2
mrpj
Drives: 2014 Icon+ 1.33l Multidrive
It looks like you have found it and the blown fuse. http://www.toyotaownersclub.com/foru...ighter-outlet/
Just remember, it has blown for a reason. Hopefully it's something relating to the inverter you used.
mrpj is offline   Reply With Quote
Old 05-04-2017, 04:39 PM   #3
toyo-ka
Haha yes! I was trying all the forums to get some help. Thanks to you and Anthony for detailed instructions on how to find it!
Old 05-05-2017, 10:14 PM   #4
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
That looks like the same inverter I have.
I haven't tried to use it in the Yaris. Look at the label on the inverter which quotes 20 amps maximum. The fuse is only 15 amps, while the owner's manual says not to use any accessories that draw more than 10 amps to avoid blowing the fuse.
If you need to continue using the inverter, consider getting a second socket installed with a suitable fuse rating and uprated wiring.
Anyone put in gauges into radio location? end user DIY / Maintenance / Service 2 03-18-2016 11:50 PM
ECT Sensor location russ1wat DIY / Maintenance / Service 2 11-08-2015 02:12 PM
Block Heater location alar DIY / Maintenance / Service 4 10-23-2012 06:45 AM
Fusebox diagram xedrabmol DIY / Maintenance / Service 0 09-28-2009 11:50 AM
diy factory aux location with aftermarked hu battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 0 10-28-2008 10:38 PM
