Old 06-19-2018, 07:53 AM   #19
dogsridewith
Drives: 2007 2-door hatchback
More like not at all.
3 clicks.
factory manual wants more than 3.
Old 06-19-2018, 12:23 PM   #20
tmontague
tmontague's Avatar
3 clicks.
That's about the amount that I have on my drums and it seems to work well
Originally Posted by B.B._07 View Post
A rear disc upgrade is a lot of work and a good chunk of change even with junkyard parts for very little (if any) reward in a small and light car like the Yaris. Not to mention the lower maintenance, parts costs and much longer lifespan of rear drums over discs.
Proper way to adjust the rear drums is to keep increasing tension untill the wheel begins to drag when you try to spin it with the drum on and the parking brake off.
Agreed. The self adjuster rarely works properly in most cars and especially not in the Yaris. Is recommend adjusting every 6 months depending on how often and how hard you use your Yaris
Old 06-19-2018, 05:08 PM   #21
Runethecursed
Drives: 2009 Yaris S
That's exactly what my issue is. I think adjusting them now
Also I have the disc rear axle beam part number if anyone cares... I want disc rears just cause haha
Runethecursed is offline   Reply With Quote
Old 07-16-2018, 03:13 AM   #22
BennyLava
Drives: 1987 Silverado
A late update:
I adjusted the rear brakes manually, and it fixed the problem. They have returned to their previous feel. Also took the time to clear coat the shiny metal drums. Hopefully that clear will hold up over the long term against the rusty look.
Mysterious Brake Fluid Loss xdarkxfirex DIY / Maintenance / Service 5 09-30-2017 08:18 PM
98k mile A/T fluid change and it's wierd?!? 07stlYaris DIY / Maintenance / Service 6 10-11-2014 01:38 PM
Should I change my brake fluid? lh59 DIY / Maintenance / Service 4 06-26-2012 11:48 PM
Brake lines/brake fluid change out jstantherprsn DIY / Maintenance / Service 3 11-02-2010 11:53 AM
Anyone have their brake pedal go rock hard on hot days? LtNoogie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 07-28-2009 11:20 AM
