Old 03-17-2017, 11:16 PM   #91
Dabuu
Radical Dreamer
Drives: spiritedly.
Much excite!
DCSports Header, 73mm to 54mm hubcentric rings, and my new static cling numbers. :)
I usually don't run hubcentric rings, but I'm tired of seeing the rust in the hubs since I don't run center caps. I'm planning to clean up the hubs/axle stubs and spraying a coat of black, to make it all purdy. :P
Running my old 319 number that I used to use in Autox. I did have a set of the 503's that I HAD to buy at an event many years ago, but one flew off that same event, fml. Since the new ones are static cling, I am going to put painters tape along the edges.
Headers, nuff said. HPS intake is also on the way. ;)
Enjoy Family Car Sports
Dabuu is offline   Reply With Quote
Old 03-18-2017, 12:09 AM   #92
tmontague
tmontague's Avatar
Originally Posted by ern-diz View Post
tmon - Would you say the KYB's are like OEM, slightly softer, or slightly stiffer?
Sorry just saw this now. The KYB's IMO are either the same or lsightly stiffer than OEM but definitely not a sport suspension setup. Save your money and go to the B8's, that's what I'm currently waiting to do and will hopefully have them by this summer
BTW nice build Dabu, keep us updated on those rear collars and how the install goes and any performance increases. I've wanted to do something about the rear end wiggle for a while but wasn't aware of this product. Looking forward to hearing how it goes
I like to drive a slow car fast...
Old 03-18-2017, 03:14 PM   #93
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Thx
Old 03-18-2017, 08:29 PM   #94
Dabuu
Radical Dreamer
Drives: spiritedly.
Thanks tmontague!
I was going to do the rear collars today, but decided I will do it another time when I have SS brake lines on hand. I needed to remove the flex section of the brake line in order to drop the front torsion beam mounts.
I painted the hubs with Rustoleum bbq grill paint, good for 1200F. And the hubcentric rings installed, so shiny.
Installed the DCSports. Big change was that cruising at highway speeds doesn't drone as much as before. I think the ecm is still adjusting the fuel trim, so I'll report back on that at a later time. Overall, the exhaust note is a little louder putt putting around town. Sounds more agressive as the revs climb. And as I mentioned earlier, quieter cruising around 65, 75, 80 mph. I love it.
Old 03-18-2017, 10:20 PM   #95
scratchpaddy
Hubcap Enthusiast
scratchpaddy's Avatar
Drives: '09 3-door 5-speed
So, the hubcentric rings are optional? Seems like that would be pretty important. They look really nice, too.
It's a shame Toyota puts the exhaust in the back. No one can see that beautiful header. :( Less drone on the highway is something even I would appreciate, though.
scratchpaddy is offline   Reply With Quote
Old 03-18-2017, 10:32 PM   #96
tmontague
tmontague's Avatar
Can't you just put a Jack under the torsion beam and then
Remove the bolts from the bushing/front mounts and kwtbthe front swing down?
Seems the easiest way as the hub and hoses can stay intact and you should still be able to get a bushing press onto the bushings
Fwiw I've installed hubcentric rings on both of my cars winters and summer rims as they're all aftermarket and it is by far something I will always do. Smooths out the wheels at high speeds and ensures safe and proper placement even with conical lug nuts
Old 03-19-2017, 10:48 AM   #97
Dabuu
Radical Dreamer
Drives: spiritedly.
As long as the lug nuts are started off and snugged down by hand, once you torque them down, you won't have any problems.
The brake hard lines that are affixed to the body start to bend due to the front set of flexible hoses not having enough slack to allow the mount to swing down pass the body.
Old 03-20-2017, 10:30 AM   #98
Dabuu
Radical Dreamer
Drives: spiritedly.
Yes owl, it's an HPS intake.
Old 03-20-2017, 12:18 PM   #99
ern-diz
ern-diz's Avatar
So, even without being able to tune the ECU, the intake/exhaust mods still produce positive gains? I've heard arguments for intake/exhaust mods improving performance and others for diminishing performance, but I don't know enough to know what's right.
Old 03-20-2017, 04:53 PM   #100
Dabuu
Radical Dreamer
Drives: spiritedly.
The factory ecm is going to try and maintain a stoichiometric air fuel mixture. After installing the breathing mods, the ecm will try to adjust fuel injection to meet stoich in normal driving conditions.
I had little hope for power, I mainly did this for the noise lol.
The car is slow, might as well make the soundtrack enjoyable. :D
Old 03-20-2017, 05:21 PM   #101
ern-diz
ern-diz's Avatar
LOL awesome.
Old 03-27-2017, 10:12 PM   #102
Dabuu
Radical Dreamer
Drives: spiritedly.
TRD Cup Rd. 2 Streets of Willow Clockwise
The day started off nice in the morning, but then became super windy through out the day. My interior is filled with Willow Springs dirt. :(
I think this is the first time TRD Cup had it's own run group! A session filled with only Toyotas! From Supercharged Corollas to big bad V8 GS400s duking it out. :D It was pretty awesome to drive our cars next to each other and then hanging out at the pits chit chatting about our set ups.
Hopefully we can keep this going as a community, and maybe one day, we'll have a TRD Cup vs vtecclub run group!
My PB of 1:34.69 placed me in 3rd place in Limited Class. :)
I definitely need more seat time. And coilovers. Which are already ordered, just need to wait 2 months before they come in from Japan. I couldn't feel any difference in power with the intake and header, but it definitely sounds better, the camera actually picks it up lol.
and of course a video link, no going off roading this time around.
https://youtu.be/2D4cpZfJcxk
Old 03-28-2017, 11:34 AM   #103
ern-diz
ern-diz's Avatar
So cool
Old 03-28-2017, 11:57 AM   #104
justanotherdrunk
clean & sober 26 years
justanotherdrunk's Avatar
Drives: 2016 SE
yep very cool
enjoyed the video
Old 04-09-2017, 01:16 PM   #105
Dabuu
Radical Dreamer
Drives: spiritedly.
Glad you guys enjoyed the track day content. :)
Installed the FDA31 Beat Sonic shark fin to get rid of the antenna stalk. The color match was pretty spot on. I'm not sure how I feel about it just yet, I do miss the antenna. I'll give it another week or so before I decide to remove it.
Old 04-09-2017, 03:18 PM   #106
scratchpaddy
Hubcap Enthusiast
On your car, that shark fin looks perfect. That's what they should have done from the factory.
The pokey antenna is a better fit for the 2nd gen cars, I think. Makes them look like little R/C cars.
Old 04-09-2017, 10:17 PM   #107
Dabuu
Radical Dreamer
Drives: spiritedly.
Maybe it'll shave a tenth off my lap times lol max aero!!
Old 04-09-2017, 11:16 PM   #108
Dodge Aries K
My Yaris is a taxi
Drives: 5 Yaris Hatchbacks
So, with your car do you notice it kind of lurches when you shift it? I haven't been able to figure out how to accelerate "fast" without it kind of lurching between shifts. I think maybe stiffer engine mounts would help but I dunno besides that.
For the record, I can drive my stick shift Shadow and Camry fine haha.
-Karl the Uber/Lyft Driver
Dodge Aries K is offline   Reply With Quote
NCP91 (Second Gen Yaris) Strut Bar fits on NCP131 (Third Gen Yaris) cwk8412 Third Gen Yaris General Discussion 8 06-20-2017 07:05 PM
FYI: Aftermarket parts from Japan (NCP131) yarisugi Third Gen Yaris General Discussion 26 01-30-2016 07:43 AM
Toyota Vitz RS 1.5 NCP131 Nas_RS DIY / Maintenance / Service 5 02-24-2015 05:27 AM
ncp131 yaris DIY DVD is out yaay enviri Third Gen Yaris General Discussion 0 01-18-2012 12:53 AM
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
