Old 09-06-2017, 02:19 PM   #1
YarYarBinks1970
Drives: 2016 Yaris L Manual
Squeaking Clutch Pedal / Linkage & Squeaking Shifter
2016 Yaris L
2 - Door
5 Speed
56k Miles (A LOTTT of highway trips)
Cruise Control courtesy of CTScott
My shifter / shift linkage squeaks between 1st and 2nd Gear
Also, the clutch pedal makes a squeak when pressing the pedal to disengage the clutch
*** Has anyone had this issue with their car?
*** Does anyone know what the fixes for these conditions are?
YarYarBinks1970 is offline   Reply With Quote
Old 09-08-2017, 01:09 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I have similar issues on mine. Probably just needs to be greased, but mine is an '09. A '16 shouldn't need that already.
Old 09-27-2017, 05:03 AM   #3
RicStyx
Drives: 2012 Toyota Yaris 1.3 -3rd Gen
It's the rubber seal where the clutch link goes through the firewall, just spray a bit of WD40 onto the rod connected to the clutch, press it a few times and it should stop.
Sent from my SM-N910F using Tapatalk
RicStyx is offline   Reply With Quote
Old 09-27-2017, 05:16 AM   #4
LTHatch
Drives: 2013 Yaris Hatchback L
Had same issue, sprayed some all purpose silicone lube on the shift linkage bushings in the engine bay and it stopped squeaking for about a month(pulled off the linkage and lubed it up after). Same 1st-2nd squeak as you are experiencing.
LTHatch is offline   Reply With Quote
YARIS Clutch Pedal Noise mik23 DIY / Maintenance / Service 3 04-27-2022 08:41 AM
HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. trini_per4mance DIY / Maintenance / Service 42 03-27-2017 03:59 AM
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 10:42 AM
Micro Image Short Shift Kit DIY jpmck03 DIY / Maintenance / Service 17 02-24-2014 07:57 AM
Sqweek while shifting (MANUAL) dallas DIY / Maintenance / Service 43 09-01-2010 03:57 PM
