Old 06-30-2012, 12:44 AM   #1
Hershey
Arrow POST YOUR OIL CHANGE ( D.I.Y. or other party ) ...
Date of change : 6/29/12
Oil :
In : Shell synthetic 5w-30
Out : Shell synthetic 5w-20 ( 4,716 miles on oil )
Oil Filter :
On : AC Delco PF1233
Out : Toyota ( Denso ) 90915-YZZF2
Car took around 3+3/4 quarts and is at Full mark .
Old 06-30-2012, 01:14 AM   #2
eddy
love to drive
Drives: 2010 yaris sedan
last oil change : may 19 2012
oil: Quaker state 5w30
filter: fram tg4967 tough guard
next oil change second week of July 2012 do one every 4000km
eddy is offline   Reply With Quote
Old 06-30-2012, 08:01 AM   #3
craigq
Drives: '07 Yaris, '12 GLI
Out: M1 5W30, OEM filter
In: Canadian Tire Motormaster Formula 1 conventional 5W30, OEM filter
craigq is offline   Reply With Quote
Old 06-30-2012, 01:00 PM   #4
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
Out: Mobil1 Syth 5W30, OEM filter
In: Toyota Oil 5W30, OEM filter
caineroad is offline   Reply With Quote
Old 06-30-2012, 04:09 PM   #5
dferguson2
Drives: 2008 yaris sedan
last oil change
08 yaris sedan
91,000 miles
Mobli 1 5w20
Fram xtra guard filter
I change every 10k miles.
I put on at least 40,000 miles per year, use only summer months (wifes car in winter, I use a '12 Subaru Forester) bought with 45K last year.
dferguson2 is offline   Reply With Quote
Old 06-30-2012, 07:19 PM   #6
zkay
Drives: 2010 Yaris Sedan 4-DR
In: Mobil1 A.F.E. 0W-30
Out: Toyota 5w-20
In: Wix #51394
Out: Toyota OEM filter
Put (what I thought was) about 4 quarts in, after reading the manual online and seeing it required 3.9 quarts for a change with filter. Drove it about 800 miles, after noting several times the oil dipstick read over full (weirdly). Drained out 300ml of oil, it now reads dead on "full", when the motor is both hot and cold.
I did this at or around 4800 miles on the previous oil / filter.
zkay is offline   Reply With Quote
Old 07-02-2012, 08:06 PM   #7
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
Oil in: Royal Purple 5W-30 performance oil
Oil out: OEM 5W-30(changed every 5k miles at a dealership since it was under warranty)
Miles on car: 34.3k originally, then again at 36.7k miles
K&N oil filter
car reached 3 year warranty limit before I got 35k. didn't buy an extended warrenty after all it is a Toyota.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood
Old 07-02-2012, 09:58 PM   #8
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
First oil change at 1,100 miles.
Castrol Synthetic 5-30
Fram Tough Guard Oil Filter
Drilled oil plug and installed magnet to capture and hold steel particles until the next oil change.
Oil filter seeping oil from seal : Should I change it ? Hershey DIY / Maintenance / Service 33 11-14-2012 04:25 PM
Dealer oil change boggydee DIY / Maintenance / Service 16 06-30-2010 11:21 PM
First DIY oil change but... derickveliz2 DIY / Maintenance / Service 31 02-02-2009 11:36 AM
Oil change time intervals PaidTimeOff DIY / Maintenance / Service 17 01-29-2009 07:14 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
