Old 09-16-2013, 02:09 PM   #1
cbrodlo
Drives: 2009 Toyota Yaris
I think I just blew my ECU while putting in an aftermarket radio
Hello all,
While attempting to install a new head unit into an North American 09 LB, I think I may have blown the/an ECU. Here are some of the variables I'm working with while trying to diagnose the exact problem:
-Everything works but the car will not start, starter clicks very rapidly like no other dead battery I've encountered. Think I will have it tested anyway. I also jumped it.
-The head unit in question is a Pioneer AVH-X8500BHS. The harness was professionally soldered and shrink wrapped by a friend, with one catch. I ordered a kit on amazon used to bypass the requirement of the parking brake in order to watch video while moving (i just wanted the option, i would not drive while watching a movie). I lost the instructions, so we had to guess where 2 of the 3 wires went. Obviously black to ground, but we guessed blue to blue, light green to dark green. I think this is where we may have shorted something out.
-I checked "most" fuses, but was in a rush and feel I need to check again. EFI fuses were good.
-What I believe is the nail in the coffin is when I tried to scan for error codes, my scanner only states linking error. Perhaps it may be a burned out wire, but shouldn't the fuses prevent a wire from burning? I smelled no burning. If it is the ECU, where exactly does that leave me? I know they are cheap but will need to have some sort of dealer work done on them.
-Thank god I still have my MR2 to get me places.
Thank you all for any input.
cbrodlo is offline   Reply With Quote
Old 09-16-2013, 02:12 PM   #2
Do this first, more thoroughly?
Old 09-16-2013, 02:57 PM   #3
The four fuses your might have popped are MET, ECU-IG, and ACC (all under the bottom of the dash) and DOME (in the under hood fuse panel).
DOME and ECU-IG will prevent the ECM from powering up.
Old 09-16-2013, 03:53 PM   #4
cbrodlo
Turned out the battery was much more dead than I thought. Never seen one drain so fast. Also that ECU code really put me in a tizzy. Mistake of a mere mortal. At least I've learned a partially dead battery can mimic a bad ecu.
/thread
Tags
ecu, short, wiring
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 02:12 PM
No AM radio signal on two aftermarket HUs? atebit In Car Entertainment + Electronics (audio / video / alarm) 21 10-08-2014 04:15 AM
ATL, I want to trade my Upgraded built in radio... matthewallanstill Southeast 2 03-28-2009 06:29 PM
Factory wire harness or plastic aftermarket piece for aftermarket radio????? Yarisguy13 Great Lakes 1 09-17-2007 10:14 AM
Toyota AUX plug w/ aftermarket radio? eight_heads In Car Entertainment + Electronics (audio / video / alarm) 20 09-07-2007 02:41 AM
