12-16-2018, 02:47 PM | #1 |
Drives: 2008 Yaris 3DR Hatch MT Join Date: Dec 2018
08 Yaris water leak troubleshooting help requested
My kid's '08 Yaris hatchback leaks from under the dash, between the steering column and the fuse panel. The carpet behind the pedals is wet and I think the source of the leak is in that area. There was an inch of water in the driver seat floor pan. There what I have done so far:
1. Regasketed the tail lights. They were leaking too. 2. Removed the squirrel nest from under the wiper motor and opened the drains. 3. Pulled the seats and carpets. 4. Checked the floor pan drain plugs. 5. Put a halogen lamp under the dash to see if any light was visible from the engine compartment. Light coming from AC line set opening. Not where the water is coming from but I sealed it up to keep the squirrel out. (Found a bunch of seeds and nuts under the carpet.) 6. Read all the other leak threads. I'm kind of at a loss for where to search next for the source of the leak. Any thoughts? Update: I just found two decayed foam gaskets behind the strut towers. Looks like the water runs off the windshield and partly down the cowl drain and partly past these gaskets. Maybe into the cabin? Applied some RTV and we'll see. Thanks. Last edited by 2bz; 12-16-2018 at 04:20 PM. Reason: Update. |
12-16-2018, 06:18 PM | #2 |
Drives: 2007 2-door hatchback Join Date: Jul 2016
Might as well confirm clear the HVAC box drain tube over on the passenger side.
12-16-2018, 06:44 PM | #3 |
While its all torn apart, might as well.
12-18-2018, 12:16 AM | #4 |
Drives: Yaris 06 - 5dr hatchback Join Date: Aug 2015
You should get in the car and have someone spray it with a hose pipe to see if you can locate where its coming from. I had a similar issue with mine that turned out it was a hole in the windscreen sealant and it was running all the way down the inside of the bulkhead and into the passenger foot well.
- Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles UK to Nordkapp in a Yaris
12-22-2018, 03:51 PM | #5 |
Big rain last night. Wet again on the driver's side. Wet way up under the dash behind the clutch pedal. SH1T!. I pulled the wiper pan out and noticed some corrosion/small hole on the firewall right next to the cowl drain that dumps into the wheel well. Filled the hole with silicone. Around the windshield seams dry. I am out of ideas. Could really use some insights. Thanks.
12-22-2018, 05:37 PM | #6 |
The hose idea as been put out there and I think you should do it. Get a mate to hose that sucker down while you have your head on the floor boards looking up with a flashlight.
Thread Tools | |
Display Modes | |
Similar Threads | ||||
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
Water leak to passenger side AND driver side | TMR3 | DIY / Maintenance / Service | 7 | 05-21-2017 07:19 AM |
New Yaris race car | Jason@SportsCar | Tracking, Racing, Auto-X Forum | 83 | 11-01-2012 02:32 PM |
Water Leak! Failed Relays | cfeng | DIY / Maintenance / Service | 0 | 12-13-2010 05:21 AM |
2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 04:54 PM |
