Old 04-02-2019, 01:49 PM   #145
Maritime
Drives: 2008 yaris 5dr hatch
Originally Posted by YarMatey View Post
You could just go to a tire shop or an auto junker and see what a cheap used tire that size would cost. I imagine not much. Might be able to give you a better idea for trimming if you have some actual rubber that size.
Interested to see how those grabbers look on there! They’re going to be some beefy tires!
good point, I have the HF tire changer for bike tires and have taken tires of car rims with it, If I can get a scrap one in the right size I could swap it and inflate it probably easier than making a dummy tire. The only thing is they are pretty rare tires around here. When I went in to my shop and asked them to look at them for pricing, the guy argued they didn't make that size and was surprised when they came up available in their system. If I still had my 15" rims I could find a tire in the P-Metric size that would be really close easier but I sold those rims.
Maritime is offline   Reply With Quote
Old 04-02-2019, 01:55 PM   #146
Maritime
225/70/14 exists and may be easier to find. I't pretty close in size to the 27x8.5R14. I'll try that one.
Old 04-02-2019, 04:40 PM   #147
YarMatey
Drives: 2008 Toyota Yaris 5dr Liftback
Yeah I’m sure there’s a couple sizes that would end up similar enough in diameter that could work just like you pointed out. Good luck hunting!
Hot Rhonda
- Bayou Blue
- Cosmo Racing Short Shifter
- Kenwood Single DIN Aftermarket Headunit
- Rockford Fosgate Punch 6.5” Speakers
“the dents make her handle better.”
YarMatey is offline   Reply With Quote
Old 04-16-2019, 10:24 PM   #148
YarMatey
scion xb gen1 springs: LIFT IT. LIFT IT GOOD!
With just the xD springs how much lift would you estimate it gave you? Any issues with the shocks being topped out that you noticed?
Also, Myfirstyota you said the whole strut assembly from an xD will bolt right into a Yaris with no modification? What about the rear shocks do you know?
Hot Rhonda
- Bayou Blue
Old 04-20-2019, 06:30 PM   #149
Tskm2
Drives: Yaris hatchback 06
Update !?
Tskm2 is offline   Reply With Quote
Old 04-21-2019, 11:02 AM   #150
Maritime
Originally Posted by Tskm2 View Post
Update !?
Life. LOL. I will have time wed or thur I hope to put the front and see. Backs been holding up but its clunky so need to find out why before I make it permanant. I thinknit may be shocks topping out over bumps and if thats true I need to extend them to prevent damage.
Sent from my moto e5 play using Tapatalk
Old 04-23-2019, 08:34 AM   #151
Maritime
Well it will be a little longer before I get the front done. I had my CRV V-TEC shit the bed on the drive home from NH last night and it is in the garage waiting on a new Actuator valve and it won't be out of there until that arrives Friday or Sat.
Old 04-23-2019, 04:31 PM   #152
myfirstyota
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped
I'd say an inch to an inch and a half. And yes, you must be careful when going over speed bumps etc. When the suspension dropps out. Because there is much less weight, the struts top out quick. Daily driving is no problem. But if you take a speed hump quickly, the struts will top out.
And yes, theyre a direct bolt-in. You could order an aftermarket assembled strut and you're done.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61427
Bolt-in 3.75" Suspension Lift Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61577
myfirstyota is offline   Reply With Quote
Old 04-23-2019, 04:32 PM   #153
myfirstyota
I finally got my tool issue sorted out. I expect to be done the front in 2-3 weeks. Out of town for work again tomorrow :/
Old 04-23-2019, 04:40 PM   #154
YarMatey
Oh awesome. I’m thinking with just the xD suspension and fender cutting I should be able to fit 27” all terrains. Good to know the whole strut assembly from the xD will bolt into the Yaris. I’ve searched high and low for used xD springs, the stealership wants so much I could likely just but a new set of struts and rear springs/shocks. Thanks for the info!
Can’t wait to see how the front lift goes for you, that things going to be a BEAST when it’s done!
Hot Rhonda
- Bayou Blue
Old 05-10-2019, 08:33 AM   #155
Maritime
Well lift version 2.0 is in and seems good. I'll drive it for a few days to be sure, Next I need to find a used tire in the same or close to same size to try mounting and check for clearance etc. there was a full 1.5" after the lift was installed and waiting to see if there is any settling etc. Only thing I notice is the steering is a little heavier but not bad really, I actually prefer it now as before the electric assist was too much, now it seems better. I can actually feel the height change sitting in the car too which could just be in my head LOL.
Old 05-10-2019, 12:00 PM   #156
Tskm2
Look perfect!
Old 05-10-2019, 12:41 PM   #157
YarMatey
Baja Yaris
Looks like it’s coming along nicely! I totally get what you mean about “feeling” it when you sat in the car. When I went from 175/65r14 to 185/75r15 tires I could even feel the tiny amount of tire lift I got.
Hot Rhonda
- Bayou Blue
Old 05-10-2019, 12:45 PM   #158
Maritime
Best part was normally on my drive to work there are 2 dips where the bumper hit the road, didnt happen this morning.
Old 05-26-2019, 08:40 AM   #159
Maritime
So been driving with the lift and it drives great. Selling off the winter tires I wont need and when those are sold, ill order the grabbers! Still hvaent found an old 14" tire do will have ti wrap one in old foam or something to check fender ckearances
Old 05-27-2019, 06:18 AM   #160
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
I think I have an old 14" tire or two lying around. Might be an opportunity to go for a day trip and check out the current state of the turbo Yaris.
Old 05-27-2019, 07:43 AM   #161
Maritime
Love to see the turbo in person, but do you have a 27" tire? I have 2 sets of 185/65/14 but need the 27"x8.5" 14 to check clearances
Old 05-27-2019, 08:45 AM   #162
06YarisRS
Ah, that I don't have. My apologies for not reading carefully enough. That will be one mean looking rig.
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 467 10-18-2022 10:20 AM
Vacationed in Italy - Brought home a D4D diesel Yaris CTScott Photo-Video-Media Gallery 19 07-26-2012 03:13 AM
