Old 02-25-2007, 11:42 PM   #1
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
Check Engine "Injector failure Code"
Hey
On friday morning I started the car and suddenly the "Check Engine" light was on. I drove the car all day until noon when I disconected the battery and the "check engine" light turned off. But satuday night it was back on. So I call a friend and we scan the car and the code shown was; the problem was in the Injector of the forth Cylinder. Weird thing is the car works just fine and all the other things were normal except that code. We clear the code with the scanner but I'am still worried.
Have u guys seem something like this? What can it be?
I Drive a 129whp Yaris ;)
YarisPR is offline   Reply With Quote
Old 02-26-2007, 01:05 AM   #2
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Run it in to your dealer so at least it's on record. Also, I have read these "small" injectors are prone to clogging easily?
PetersRedYaris is offline   Reply With Quote
Old 02-28-2007, 09:31 PM   #3
Moose
Resident Redneck
Moose's Avatar
Drives: 07 Polar White Yaris Sedan 5M
Not to wag my finger and give you any kind of parental speech, but why didn't you take it to the dealership in the first place? You are under warranty, right?
Check engine lights aren't something to just clear and hope it doesn't come back- it means something is wrong!
Reasons for injector failure code:
Injector open circuit
ECM open circuit (I believe it is bank 6, pin 14- could be wrong)
A/F sensor malfuntion
Fuel pump shorting
Carbon deposits on the injector
-your vehicle could actually run "normally" with all of these conditions.
Even worse, if the scantool is a generic scantool you buy at an auto parts store, the code could be wrong (I see that everyday- customers come in with an "AutoZone code" and it's dead wrong).
You gotta get it checked by a dealership, bro.
My other rides:
2003 Honda Civic LX Coupe 5M- S/C K24 w/ LSD coming soon!
1999 Honda Civic EX Coupe 5M w/ B18 powaa
1985 Toyota Celica GTS Coupe 5M- track whip
http://www.importlounge.com
Moose is offline   Reply With Quote
Old 02-28-2007, 09:36 PM   #4
ChinoCharles
Drives: LB
Yeah, take it to your dealership. No reason not to... shit, until that warranty is up make them sick of you. Its your right as an owner.
Sounds like it MAY be a good excuse for some NGK's though.
Old 03-01-2007, 09:43 PM   #5
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
Update: Took the car to the dealer(warranty) and No code showed up since they can only get a code if the car has the "check engine" light on(damn I cleared it). They told me next time it lights up bring it. But they did a general chek-up of the car and said everything was normal... except the gas tank cover was broken... they did order it. I'driving the car as I did befor the light went on... i'll wait and see what happens.
Just thinking...... when the light came on It was a week after I had taken the moffler out. At first it accured to me it must have been a sensor of air or something but i put everytjing back to normal and reset the computer and it was gone for a whole day then came back on so I discarted that idea..
Old 03-02-2007, 05:12 PM   #6
jdubau55
Drives: 2007 White Yaris LB 5 Spd.
Send a message via AIM to jdubau55 Send a message via Yahoo to jdubau55
Your fuel door was broke??? You know if your gas cap isnt on tight it might pull a CEL code. Says so right there on the gas cap. "Tighten until 1 click is heard, CEL may appear if not tightened properly" or something like that.
jdubau55 is offline   Reply With Quote
Old 03-02-2007, 05:35 PM   #7
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
One of the guys in the dealership told me that and coming to thing of it Yesterday I got gas and today in the morning the light went back on.. that really makes sense.... that might be a very good reason... but guess i'll have to take it this week again
Old 03-02-2007, 05:38 PM   #8
jdubau55
Just try re-tightening your gas cap. Mine only makes like the tinyest clicking sound. Its not like most where once you turn it so far there is like a strain relief that breaks it free. Pretty much just put it on realllll tight.
Old 03-02-2007, 05:41 PM   #9
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
I just read this and went out to chek my gas cap.. and turned it and "click" i didn't tight it enought.... hope this was the cause of the problem
thanks dude
Old 03-02-2007, 07:51 PM   #10
jdubau55
You cant really base anything on the engine codes. It might say its the injectors but who knows what it REALLY is. Hope that fixed it.
Old 03-03-2007, 06:40 PM   #11
Moose
Resident Redneck
Moose's Avatar
If the gas cap was loose the scantool should read PO446. The code is an evap system code- it has nothing to do with injector failure.
So, if the gas cap was indeed loose, it appears the scantool was incorrect.
BTW, I have never seen a Toyota factory scantool read a code incorrectly- their only funtion is to convey the message the CEL is trying to tell you.
My other rides:
Old 03-03-2007, 11:50 PM   #12
jdubau55
I can see how a Toyota scan tool will never be wrong. However, calling a friend and scanning the car does not sound like they used a Toyota scan tool.
Old 03-04-2007, 02:03 PM   #13
Moose
Resident Redneck
Moose's Avatar
You and I are saying the same thing, y0!
My other rides:
Old 03-04-2007, 04:46 PM   #14
ECHOKnight2000
Small Car Lover
ECHOKnight2000's Avatar
Drives: A Super Car
What about Scanguage? Is that reliable?
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will.
ECHOKnight2000 is offline   Reply With Quote
Old 03-04-2007, 08:13 PM   #15
jdubau55
If it aint the one at the service center it will prolly give you the same code as if you did a self diagnostic check.
Paying for the Yaris with a check? YotaYarisUSA New YARIS Purchase Forum 15 07-11-2007 03:31 PM
higher octane fuel KSIbucky DIY / Maintenance / Service 37 01-14-2007 07:17 PM
Engine upgrades aucorium DIY / Maintenance / Service 7 01-10-2007 05:03 AM
Noisy Engine David81 New YARIS Purchase Forum 8 06-02-2006 12:15 PM
