Old 04-05-2016, 12:10 PM   #1
Ramon1691
Ramon1691's Avatar
Drives: 2007 Yaris hatchback
Yaris serpentine belt!!!
Hello everyone I'm confused of what belt to buy I'm going to change the serpentine belt on my 07 Yaris hatchback but I don't know whether I need to buy the belt with AC or without AC? Can someone please help and I know I have to be very careful as I don't want to Damage the oil control valve because I replaced that 2 months ago ;)
Ramon1691 is offline   Reply With Quote
Old 04-05-2016, 12:15 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
do u have AC or not , that will answer your question.
Old 04-06-2016, 12:17 AM   #3
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
What's the reason you want to change that belt in the first place? They generally have a pretty long life time.
Sent from my LG-D801 using Tapatalk
tarkus is offline   Reply With Quote
Old 04-06-2016, 12:21 PM   #4
bail_w
Drives: 2007 Toyota Yaris LB
Looks like its about time since he has a 07 Yaris. I changed mine a while ago (120K)
bail_w is offline   Reply With Quote
Old 04-07-2016, 05:07 PM   #5
mik23
Drives: yaris 2005
Serpentine Belt Noise
Some time I heared the noise when start from cold looks to me loud squeal noise.
After 10-20min drive it disappear.
I tried soap on the belt and the noise increases.
I then clean the belt with soft brush and pulleys with the same.
The noise is v low now but I will double check this again and provide an update.
I just share this it may benefit to someone who is in same situation
so no soap or wax
clean the belt with dry soft brush.
mik23 is offline   Reply With Quote
Old 04-07-2016, 06:25 PM   #6
Lubricating a pulley system with soap. Yeah, that'll never work.
If noise is less now, chances are you increased the tension on the belt after your cleaning efforts. That is assuming you had actually loosened or removed the belt.
However, that belt, if it's original is old and a prime candidate for replacement.
Old 04-08-2016, 03:26 PM   #7
Ramon1691
Ramon1691's Avatar
Hi
I want to change it because the previous owner neglected the car I know it was change at least once because is not the factory belt but just so that I have more peace of mind :)
Old 04-08-2016, 03:30 PM   #8
Ramon1691
Ramon1691's Avatar
How often does the belt need to be changed say if I do it now with 150000 miles when would I have to do it again?
Old 04-08-2016, 08:15 PM   #9
bairjo
change the darn thing....it's not like you are rebuilding the transmission.....it's not going to break the bank and you can stop worrying about it.
bairjo is offline   Reply With Quote
Old 04-11-2016, 11:00 AM   #10
z0mb13k1ll
z0mb13k1ll's Avatar
Drives: '15 Dodge Challenger
^ +1
z0mb13k1ll is offline   Reply With Quote
yaris 1999 drive belt problem xKYLE96 General Yaris / Vitz Discussion 3 12-02-2015 10:14 AM
drive belt problem for 1999 yaris xKYLE96 DIY / Maintenance / Service 0 12-02-2015 08:24 AM
Consumer Reports Is On Crack!!! doublewam General Yaris / Vitz Discussion 82 05-07-2011 11:03 AM
2008 Yaris S driving belt socjo1976 California 9 03-16-2011 05:52 PM
