Old 10-26-2008, 05:12 PM   #1
phatjo911
Drives: 2007 Yaris Sedan
How to change Air Filter?
I watched a video where some guy said it was very easy for Toyota's to change air filters but apparently there's more to it than that
It's a '07 Yaris Sedan
Has ~35,000 miles and we don't want the stealership to take anymore money from us so I am going to change the air filter. Does anyone have a step by step instructions with pics?
Help would be appreciated.
phatjo911 is offline   Reply With Quote
Old 10-26-2008, 05:23 PM   #2
xpeteyjtx
Drives: 07 BB Yaris
Hey fellow Mass resident
It is very easy. I don't have any pictures to show, I'm sure someone else does.
It is a little difficult to explain... There are about 2 or 3 clips that hold the top of the air box. You undue the clips up and move the top of the air box up and to the side. The filter will be right in front you. Just replace it and re-install the top of the air box.
It's really straightforward. It will take you 3 minutes.
xpeteyjtx is offline   Reply With Quote
Old 10-26-2008, 05:50 PM   #3
phatjo911
thank you sir.
Good to know there are other people besides me living in mass
EDIT: I am supposed to take off the clamp connecting to the "big hose" right? ( sorry, I have no idea what it is called. )
Old 10-26-2008, 07:22 PM   #4
IllusionX
Drives: 07 Yaris Sedan Aero
noooooo.. there are 2 metal clips on the opposite side of the big clamp. it's closer to the fuse box.
Old 11-01-2008, 11:02 PM   #5
Sailr303
There Does Seem To Be A Trick
I replaced the air filter on my '07 Sedan last week. The two clips released the cover and the filter came out easily BUT I must have spent 30 minutes trying to align the cover and filter so the clips would align enough to snap! I probably would have saved time by removing the hose but it seemed like too much work at the time. What did I do wrong?
Sailr303 is offline   Reply With Quote
Old 11-01-2008, 11:11 PM   #6
b_hickman11
Drives: 08 Sedan
Once you have done it several times you will get the hang of it. You have to make sure that the 2 black plastic pieces on the left side of the air box slide into place first. Then you can lower the right side down and engage the 2 claps.
Old 11-03-2008, 12:10 AM   #7
touroxin
touroxin's Avatar
Drives: 2008 Yaris 5M Blazing Blue HB
How often are you guys changing the air filter?
touroxin is offline   Reply With Quote
Old 11-03-2008, 12:55 AM   #8
YarisSedan
YarisSedan's Avatar
Drives: 08 Yaris Sedan
Send a message via AIM to YarisSedan
Depends on where you live and how dusty the area is. If you live cross country then maybe once a year. Easiest way to tell if it needs changing is remove it and hold it up to a light source. You should be able to easily see light in between the veins. If not then its time to change. Or if it looks dark black and is plugged full of leaves.
Old 11-03-2008, 12:44 PM   #9
b_hickman11
Drives: 08 Sedan
I have a K&N filter in both of my Yaris's. I personally believe you cant go wrong with them. They only cost $41 and will last you a lifetime. The dealer quoted me $25 for a replacement filter so the K&N will be paid for after 2 changes of a regular filter.
Old 11-03-2008, 06:09 PM   #10
touroxin
touroxin's Avatar
Thanks guys!
DIY Cabin Air Filter BailOut DIY / Maintenance / Service 105 06-20-2019 12:59 PM
Liftback Air Conditioning (Cabin) Filter info Snappy DIY / Maintenance / Service 24 10-01-2010 06:36 PM
air filter multipart btc50 DIY / Maintenance / Service 1 08-31-2007 06:37 PM
damaging or no--cabin air filter roxy84 DIY / Maintenance / Service 3 06-29-2007 01:17 PM
