01-19-2019, 05:20 PM | #1 |
Drives: oh7 midnightblu Join Date: Jan 2019
head gasket replacement Oh7yaris
is it even necessary to remove the knock sensor for this project??? And should I replace timing chain. anything y'all can help me out here with would be well received. I've removed:
valve cover intake manifold exhaust manifold(mid-post){removing mani from pipe now and all other little associated sh@*! that goes in the process of getting to this point. finishing mani/pipe now.... thx RL416 |
01-19-2019, 05:48 PM | #2 |
exh mani extracated,
necessary to remove timing chain cover?? |
01-19-2019, 06:04 PM | #3 |
anyone out there interested in popping my forum cherry???
01-19-2019, 07:02 PM | #4 |
Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
When I did this job on my wife's '02 echo (just for kicks) I removed the timing cover but had enough room to keep the engine in the engine bay.
The repair manual calls for removal of the timing cover and I honestly dont know if you can get away with doing it with the cover still assembled. I would just remove it. I'd leave the timing chain unless you had specific issues with it, those things last forever in these engines. Knock sensor sits on the block so it doesnt gerd to he touched. Make sure you have a manual showing you how to reset the timing and where to place the rtv when reassembling.
No one ever wants to give a Yaris the point by... |
01-20-2019, 04:47 PM | #5 |
tmontague: Thanks for getting back to me sir. I’m currently trying to get a service manual, I came across a thread that had two links to no avail, and another that says go to the last page in the forum???
01-20-2019, 06:58 PM | #6 |
I have the pdf on my google drive, but I dont think I can email you the full thing and I'm not the most IT literate person.
A Haynes manual will also work well. I believe there is a website that for $20 will give you full downloadable version of the factory repair manuals, I just cant remember the name off the top of my head
01-21-2019, 12:23 PM | #7 |
Drives: 2007 4dr sedan Join Date: Jun 2009
Try this site: https://cardiagn.com/1nz-fe-engine-m...cylinder-head/
Similar Threads | ||||
Head gasket location and part | vidfan | General Yaris / Vitz Discussion | 5 | 11-17-2016 12:57 AM |
Front Exhaust Gasket Replacement | tmontague | DIY / Maintenance / Service | 6 | 03-25-2015 10:00 PM |
07 Yaris S Blown Head Gasket? | ylerT | DIY / Maintenance / Service | 7 | 06-26-2013 01:19 PM |
Head gasket | thefalls | Forced Induction Forum | 12 | 11-12-2012 12:26 AM |
Custron T1062TYT Review (Long) | mr.steevo | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 11-24-2011 02:13 PM |
