Old 05-25-2018, 08:12 PM   #1
logoris
Drives: 2017 Yaris SE Blue Streak
Exhaust leak at 20k km
Has anyone else experienced an exhaust leak coming out about the driver's door with low milage?
I'm noticing mid range rpm it goes out the side, instead of the rear
Sent from my SM-G930W8 using Tapatalk
logoris is offline   Reply With Quote
Old 06-05-2018, 01:54 PM   #2
logoris
Will be taking it into the stealership will let everyone know
Old 06-05-2018, 05:15 PM   #3
Dliverance
Drives: 2012 Black sand pearl <3
I wonder if it was poor installation and not a faulty part.
Dliverance is offline   Reply With Quote
Old 06-06-2018, 12:46 PM   #4
DarkShadowFox
Drives: 2015 Yaris LE 3door 1F7
probably a bad gasket or somethings not tight, when did it stop, did you bring it into a shop recently.
DarkShadowFox is offline   Reply With Quote
Old 06-08-2018, 07:05 AM   #5
logoris
It's been going about 2k km now. I didn't notice any event that would cause it to change
Old 06-08-2018, 01:13 PM   #6
DarkShadowFox
Start the engine, and have a helper block the tail pipe with something like a piece of 2X4.
You’ll find the exhaust leak pretty quickly.
Tester
via toyotaworld or we forum i found it on, standard procedure as they are the same engine and design as a 2010
Old 06-26-2018, 01:15 AM   #7
logoris
Ok dealers have said they can hear it but there is nothing to fix.
Maybe I'm wrong does anyone else get a deafening drone from the factory exhaust 3000+rpm underload
Toyota Canada says that unless a dealer says there is a problem they will not cover it
Newbie with an exhaust leak on his '06 Yaris ToYarta DIY / Maintenance / Service 49 01-03-2019 12:50 PM
My Echo Exhaust Leak in Front ? frank2005 General Yaris / Vitz Discussion 8 08-02-2017 08:52 PM
Enkei's and Dunlops + Medalion Touring Exhaust 2manywheels Items for Sale by private party 40 04-04-2011 05:01 PM
