Old 04-28-2017, 04:27 PM   #19
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Had to replace both sides at around 90k.
Sent from my XT1635-01 using Tapatalk
Old 05-02-2017, 03:40 PM   #20
tmontague
tmontague's Avatar
Just an update. I swapped in new bearings and the vibration was still there. It turned out to be my drivers side axle which is but it's maximum compression since the 2zr is wider. When I turn hard, the wheel is pushed in causing the axle to shorten. Because it already is maximally compressed it starts to push the engine and trans instead which causes a vibration as the axle rotates.
My bearings were starting to get crunchy and the rear wheels soon better now so it wasn't a total waste. The bearing would have likely only lasted another 10-20k km before they started making noise
Old 05-05-2017, 08:50 PM   #21
SirDigby
Drives: 2007 yaris 3 door
huh. good to know!
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
new wheel? Nekofelin DIY / Maintenance / Service 1 08-10-2010 02:37 PM
2007 3 door 350000 miles eats wheel bearings! webfeet69 General Yaris / Vitz Discussion 23 12-15-2009 08:20 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
