Old 03-03-2011, 05:02 PM   #1
Josepe-sv
Drives: Yaris 2008 HB 1.5
How to reset (!) light
I was reading a similar post of this panel ligt, but is a large list of replays...
The tires are ok, pressure 30Lb like manual says, alignment and balancing ok.
Can this item report suspension problem?
How reset?
Josepe-sv is offline   Reply With Quote
Old 03-04-2011, 10:15 AM   #2
teddy
Drives: 2008 5-door hatchback
Send a message via MSN to teddy
Assume you're referring to this light? This light could indicate a brake problem. It also lights up if you have the handbrake engaged. Might seem like a silly thing to suggest, but do you have the handbrake released?
teddy is offline   Reply With Quote
Old 03-25-2011, 07:28 PM   #3
Josepe-sv
No, is a icon like tire figure.
Old 03-25-2011, 10:23 PM   #4
You may have a bad sensor. Check out this post for instructions on how to get the TPWS ECU to flash its light to tell you what the problem is:
http://www.yarisworld.com/forums/sho...8&postcount=11
how to reset airbags light tonoyaris DIY / Maintenance / Service 4 07-26-2016 08:12 PM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
tire pressure light won't reset nikvolkert DIY / Maintenance / Service 6 10-24-2010 03:58 AM
How do you reset the TIRE PRESSURE WARNING LIGHT penny09 DIY / Maintenance / Service 3 09-26-2010 02:53 AM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
