Old 08-14-2013, 08:22 PM   #1
yaris1F8
yaris1F8's Avatar
Drives: Yaris 1F8
Wheel well removal?
Anyone here can help out.. i was torquing a screw holding the cowl cover right at the strut, and i dropped my 10 mm short wrench in the fender.. damn..I felt it go all the way down..haha.. I tried with a magnet but to no avail.. the thing is when im driving i dont hear it banging around, sounds like its wedged.. Does this mean i need to remove the wheel well cover.. anyways can someone help out.. lol
yaris1F8 is offline   Reply With Quote
Old 08-14-2013, 09:47 PM   #2
I would say that it is likely wedged between the fender liner and the fender. You can release a couple of the clips on the wheel arch to get a peek in.
Old 08-14-2013, 10:44 PM   #3
yaris1F8
yaris1F8's Avatar
Drives: Yaris 1F8
Hi CTScott i did that and i push my magnet in there moved it around.. no catch.. im guessing i will need to remove the wheel well.. is this a big job ? Damn.. not being to lucky these past couple weeks. Btw the popping noise i was hearing was the cowl cover, has a busted screw.. I had to drill and retap.. put in a new screw.. no more noise. :)
Old 08-14-2013, 10:46 PM   #4
If by wheel well, you mean the whole fender, then it is a bit of a hassle. I would start with just freeing the fender liner, as that will give you full visibility under the fender.
Old 08-15-2013, 12:26 AM   #5
yaris1F8
yaris1F8's Avatar
Drives: Yaris 1F8
I meant the inside of the fender.. the black plastic covering.. i bought all new clips, i figured some might break off so.. Now i need the time to do this, its looking good for friday morning. (y).. I hope i find the 10 mm
Old 12-01-2013, 04:23 PM   #6
CB Spoolmak
I am guessing that removing the front wheel first before the fender liner would facilitate ease of access/egress? I am following the hood release cable & it hides behind the driver side wheel well liner.
CB Spoolmak is offline   Reply With Quote
Old 12-01-2013, 05:13 PM   #7
Yes. Removing the wheel gives you far better access.
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
