10-03-2015, 07:55 AM | #19 | |
Drives: 2009 Yaris Join Date: Jan 2014
Half the time, I don't even use the clutch while getting up to speed on the highway. |
10-03-2015, 08:23 PM | #20 |
Drives: 2011 3dr LB Polar White Join Date: Apr 2011
10-03-2015, 09:08 PM | #21 | |
It is possible, if you know where the sweet spot is, to shift without needing to clutch it. Sent from my iPhone using Tapatalk
10-04-2015, 07:26 PM | #22 |
Drives: 2007 yaris 3 door Join Date: Sep 2015
do you do this because Fast&Furious told you to? why would you do this?? all this will do is make your master cylinder wear out twice as fast! do you have a straight cut gears in your trans? are you missing synchro rings? why would you double clutch???
10-04-2015, 07:31 PM | #23 | |
same thing with using transmission as a engine brake, sure it will bog the engine causing friction resistance and slowing of the vehicle, but brake pads cost $60 where a worn out transaxle costs....much more |
10-05-2015, 04:20 AM | #24 |
2ZR swap. DO IT! Ask how!
For daily driving, sure. For performance applications, you can't beat the combo of brakes + engine deceleration. There's no way I'm going to clutch in while setting up for a hard corner. =)
10-05-2015, 02:37 PM | #25 |
Mr. 155 and climbing
2007 Sedan
miles: pulled at around 45k miles I upgraded to the CCI Stage 3 clutch and ultra lightweight flywheel combo. For a long time it was one of my best investments other than going turbo. Last fall during my speed runs I pretty much did a lot of stress damage to the pressure plate apparently because about 6 weeks later I had 3 of the 5 springs let go on it (25k miles on the setup). I would never buy another CCI product again personally. I contacted them because they stated that the clutch assembly should hold up to 300whp/280tq. I was running 250/245 and yet the pressure plate broke. I don't hoon on the car nor do I do things like auto x, etc. I asked them to meet me in the middle on a replacement and they flat our refused. This was the straw that broke the camel's back. I can prove via dyno results where my power was at and my logs on my EMS can show that I didn't over rev nor abuse the clutch. The first issue that I had with them was that they claim to have payouts for setting records and winning races. I sent them my information back in 2012 when I set 6 new records. They informed me that Land Speed Racing isn't well enough known for a payout?!?!? Last time I checked Bonneville Speed Week is a pretty big deal, but whatever makes them sleep at night. I upgraded to a Stage 3 setup from ACT this time around. It is their best and highest rated kit for street/track use. It is a 6 puck, but I have been told by a few very good sources that have them equipped on their 1nz that it is a very usage scenario for DD so we shall see in a couple months when the car is buttoned back up.
10-05-2015, 04:27 PM | #26 | |
Drives: 3-door hatch Join Date: Oct 2010
Synchros or not, double clutching makes for smoother downshifting under certain conditions if done correctly. |
10-15-2015, 11:22 PM | #27 |
Drives: 08 Yaris hatch Join Date: Oct 2015
Just recently started trying to rev match while down shifting but with no tach and a stereo that drowns out any sounds from the car its a lil difficult, but I feel like I'm getting the hang of it, just wanna get some wider pedals cuz the stock ones are tiny
Sent from my XT1254 using Tapatalk |
10-16-2015, 09:59 PM | #28 |
Drives: 2009 5-door, 5-speed Join Date: Sep 2011
To add my experience:
Replaced the OE clutch at 70,000km. Clutch still had probably 60-70% material, but some pressure-plate springs were soft (Clutch height was erratic). The release-bearing also was wearing through the springs pretty bad. I do a fair bit of autoX with the car, and drive on R-comps for several months a year. Pretty hard on things. The OE clutch is VERY sturdy built. Don't worry about a little slipping, or the occasional jerky engagement; It won't hurt it at all. Toyota built these clutches to last. The flip side is they are heavy. I installed a LUK kit which was a fair bit lighter (and will not last nearly as long). The lighter weight allows a small, but noticeable difference in acceleration. Pedal feel is similar (poor) with maybe 10% more effort required than the OE clutch. |
10-17-2015, 02:55 AM | #29 | |
10-18-2015, 09:52 AM | #30 |
Drives: 2010 3dr Yaris Join Date: Oct 2010
2010 bought new, now has 222k miles on clutch. Only problems has been rear wheel bearings.
11-05-2015, 11:02 PM | #31 | |
Drives: NCP91 Join Date: Jul 2012
In doing this, pushing the shift lever into the gates during a downshift requires, literally, almost no effort, with only a cunt hair of resistance from the shift rod detents. Mind you, my Yaris gearbox still sees significant and frequent abuse. My upshifts are still normal "granny shifting" and is the only time my synchronisers are being used. |
11-07-2015, 03:36 PM | #32 |
Drives: 2010 Yaris hatch Join Date: Mar 2011
2010 three door, bought with 6000 milea in 2011. Now a bit over 70k, no issues as far as I know. But I'll tell ya - next car if I stay in SoCal will be an auto.
"I like the dreams of the future better than the history of the past" - Patrick Henry |
11-15-2015, 11:22 PM | #33 |
Drives: 2010 Carmine Red hatchback Join Date: Mar 2009
I'm the original owner of my 2010 hatchback.....bought it right at 6 years ago (Nov. 2009). It has 123k miles and still has the original clutch, which is functioning just fine. Most miles are highway......probably a 60/40 highway/city split.
Similar Threads | ||||
Getting Rid of the infamous Clutch "Shudder" | tmontague | DIY / Maintenance / Service | 14 | 07-08-2023 01:56 PM |
Clutch Maintenance | fnkngrv | DIY / Maintenance / Service | 12 | 03-03-2017 10:42 AM |
Unique Smell from Air Going Through AC Blower | EddieCabael | DIY / Maintenance / Service | 30 | 01-19-2015 09:08 PM |
need help on my 2008 yaris compress clutch | susucosp | DIY / Maintenance / Service | 0 | 05-15-2014 03:48 PM |
Having clutch issues ? | hystria | DIY / Maintenance / Service | 10 | 08-22-2007 11:34 AM |
