01-22-2016, 01:48 PM | #1 |
Small cars are a big deal
Drives: 2007 Yaris Liftback Join Date: Feb 2006
AVS In-Channel Ventvisor Pics
Anyone have pics of AVS In-Channel Ventvisor pics on their three-door Yaris? I've found a few via searching, but not sure if they're in-channel or not.
Subcompact Culture: The Small car blog |
01-23-2016, 06:32 AM | #2 |
Drives: 2010 Yaris Sedan Join Date: Feb 2010
AVS makes them for the Yaris both ways. Stick on and in channel.
01-23-2016, 08:54 AM | #3 |
So these are what you are requesting? There is no question that these are in-channel.
01-25-2016, 12:52 PM | #4 |
Right, but are they AVS or Weather Tech? (Or someone else's?)
01-25-2016, 01:04 PM | #5 |
Thread that the pic came from states they are AVS. I wouldn't have posted otherwise.
01-25-2016, 01:26 PM | #6 |
Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
I have AVS's on all 4 doors on my sedan. They look exactly like the the ones in the pic WeeYari posted up.
Work great. I'd recommend leaving your windows up for 24hrs after the install to set the glue. The window holds the visor tight against the door and will keep the glue on the tape firm against the door to set it. I've had mine since the summer and zero issues so far.
No one ever wants to give a Yaris the point by... |
01-25-2016, 03:02 PM | #7 | |
Don't the WeatherTech in-channel visors just pop in? |
01-25-2016, 03:08 PM | #8 |
It was my first time using window visors so I had nothing to compare them to. They have a thin strip of double sided tape on the front side of the in chanel part. When the window is up, it pushes against the visor pressing the tape against the door.
I couldn't imagine it without the tape. When the window is down nothing would be holding the visor to the door. I guess it just gives extra security and also stops any chatter it could make when the window is down and you're on the highway.
01-26-2016, 08:46 AM | #9 |
Drives: 2010 Blazing Blue 3 Door LB Join Date: Dec 2013
I have AVS in channel visors I bought from Scott a while back. I received them second hand and do in fact have double sided tape from the factory. I cleaned the old tape off and applied new tape.
Also, be sure to clean the inside track really good with a microfiber towel and some good cleaning solution then let it air dry and then do a final surface prep with alcohol. I love mine, I think they look great but it took me a little while to get used to them since it makes the window frame about twice as thick and takes some time to get adjusted to the amount of side window glass you have to look out of.
15' - Crosstrek Hybrid ~ Plasma 10' - Yaris 3 Dr LB ~ The Boom Box 06' - RSX Type S ~ H.S. Dream Car 95' - Delsol VTEC ~ The Racecar 12' - Burgman 400 ~ Garage Queen 09' - Agility 125 ~ 80mpg Daily Rider 09' - Metropolitan ~ Weee 14' - Ecosmart Metro ~ Razor |
01-26-2016, 11:16 AM | #10 | |
01-26-2016, 12:06 PM | #11 |
In comparison to ones I've seen on Honda's where I live they do not protrude too far, maybe 2-2.5" from the top. The pic WeeYari posted gives you a good idea.
Some of the one's I've seen on cars around here look plain silly. They're massive and they are over channel so they just look goofy and not factory at all
01-26-2016, 01:56 PM | #12 |
The AVS profile appears to be quite similar to my Toyota visors. Basically, they sit proud of the window enough to slip your fingers in under the edge. So maybe 1/2 to 5/8th inch. My car is not handy to me at the moment so I cannot actually measure the cap between window and visor.
Similar Threads | ||||
Left Channel coming out Both Speakers suddenly | MedMantle | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 11-28-2015 07:43 AM |
FS/FT: Eclipse 3650 4 + 1 channel amp | yaris2010RS | Items for Sale by private party | 3 | 03-11-2011 11:24 AM |
Issue for LP setting on 4 channel amp. | YarisSedan | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 02-08-2010 12:10 PM |
bridging 4 channel amp | o2cavyss | In Car Entertainment + Electronics (audio / video / alarm) | 20 | 01-21-2010 03:40 PM |
Stick On or In Channel Visors | schreck | General Yaris / Vitz Discussion | 20 | 04-22-2009 06:27 PM |
