Old 07-13-2015, 12:43 PM   #1
dstephens1962
Drives: 08 yaris
2008 srs airbag
Hello all,
I have an 08 yaris with the srs airbag lit. I jumped the codes and came up with 32. I tried clearing the codes and checked the connections and that did not do the trick. I'm assuming that I need to replace the squib pad in the passenger seat. Where is the best place to find one cheap and is there a write up on how to install?
Sent from my SAMSUNG-SM-G870A using Tapatalk
dstephens1962 is offline   Reply With Quote
Old 07-13-2015, 08:56 PM   #2
32 is a problem with the Occupant Classification System. This is not a squib, but rather is the system which weighs the passenger and decides if the passenger weighs enough to be able to handle an airbag in the face.
Look under the front edge of the passenger seat an you will see a small black module with two connectors plugged in. Make sure that both are properly seated.
Old 07-13-2015, 09:51 PM   #3
dstephens1962
Drives: 08 yaris
Yes, they are both plugged in. I checked all the cables to the seat. And tried to restest the light via jumping it and disconnecting the battery for 20 min wich did not work.
Old 07-13-2015, 09:51 PM   #4
dstephens1962
Drives: 08 yaris
Jumping the pins in the ob2 port.
Old 07-13-2015, 10:01 PM   #5
OK. Unfortunately to diagnose any further would require the Toyota TechStream tool. If you are interested, I have a spare (and tested good) OC ECU on hand.
Old 07-13-2015, 10:03 PM   #6
dstephens1962
Drives: 08 yaris
Is there a way to just bypass the thing? I can pick up that box from my local pick and pull for 35 vise the 200 plus off the Internet. Should I just chance it?
Old 07-14-2015, 06:37 AM   #7
Bypassing it requires a more expensive device. The $35 shot is probably worth it, as I have never seen the sensors fail, but have seen people have the OC ECU fail.
Old 07-15-2015, 06:04 PM   #8
dstephens1962
Drives: 08 yaris
I talked to a dealer out here in Cali about the recalls on the vehicle, since the vehicle has an outstanding recall on the srs system and the passenger seat rails they will fix it for free
Old 07-15-2015, 06:30 PM   #9
Nice!
2008 Yaris HB Airbags SRS xnamerxx Items for Sale by private party 0 03-29-2015 01:16 AM
SRS warning light, pass. seatbelt light, pass. airbag light PROBLEMS! tylerwatts53 DIY / Maintenance / Service 1 07-17-2014 08:53 AM
2008 yaris sedan airbag... Din get answer anywhere yet... Abk911 In Car Entertainment + Electronics (audio / video / alarm) 3 04-08-2013 11:33 PM
WTB: Stock Drivers SRS Airbag & SRS CPU 03Z33 Willing to Buy by private party 0 06-26-2009 01:41 PM
srs / airbag light after head unit install? KwonSau In Car Entertainment + Electronics (audio / video / alarm) 7 12-24-2008 02:04 AM
