Old 01-02-2019, 04:36 PM   #37
myfirstyota
3 Yaris and counting..
Pics are great! Enjoyed looking at them. If find that 1024 x 786 or 800 x 600 make it easier to see them and keeps from having to scroll to read the text. But, who's complaining.
I'm pretty new to all this pic hosting and resizing stuff. I'll be honest... it's a miracle I was even able to get pics up haha. Engine swap.. cake walk. Posting pics.. it's been 3 hours on 2 devices just for what you see posted lol
Old 01-02-2019, 04:43 PM   #38
Use your phone ;) but then the tradeoff is looking at a complete, little pic. I feel your pain tho with the huge ones viewed on a computer.
Old 01-02-2019, 04:52 PM   #39
myfirstyota
On my Samsung note5 there's very little scrolling. On my old Huawei mate 2 it's a lot of scrolling. I think it depends on your device how bad it is.
Old 01-02-2019, 09:09 PM   #40
myfirstyota
Bump for new info and pics
Old 01-02-2019, 09:34 PM   #41
06YarisRS
Drives: 2006 Yaris RS
Yeah, for sure. Sometimes I use my phone, but then it's too small. I just can't be pleased.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.youtube.com/watch?v=5Edvs_TSGkY
2008 Yaris LE H&R 10mm spacers (rear), RS rear spoiler
Old 01-02-2019, 09:43 PM   #42
06YarisRS
Hell, miniscule inconvenience for all the excellent info you're providing. Love the new pics. I love the really meaty winter tires on the blue Yaris! Also, your axle/cradle 'restorations' are awesome. I once thought about removing my struts, degreasing, sandblasting (my neighbour a couple houses away has a sandblaster), priming and painting. I settled for spraying atf on them every few weeks. They look nice and black.
Old 01-02-2019, 10:07 PM   #43
myfirstyota
Yea the rear axle came out well considering I found it literally sitting in gravel. That's why I went with new bearings.
Cleaning and painting everything has literally taken 10-15 times longer than the swap would have if I just pulled and reinstalled the engines. But this is a build... Not just a swap.
Blucar is hopefully getting a 3-4" lift kit this week. A custom bolt-in idea I've been working on with inspiration from crashy, ctscotts plow/dump...car. If I get that working well, then there's plans for 215/75/15 A/T tires on some horribly offset rims lol. Gonna need to figure out some fender flares for that set up. But that's another build thread! Lol
Old 01-02-2019, 10:19 PM   #44
06YarisRS
Cleaning and painting everything has literally taken 10-15 longer than the swap would have if I just pulled and reinstalled the engines. But this is a build... Not just a swap.
Oooh...Yarisworld is getting more exciting all the time. Will be following the 'lift' thread, assuming you do one. You know, you'll be going against the tide, here. Everyone seems to want to get lower to the ground, not higher from the ground.
You may have seen it already, but I think some guy down south or in Australia (EDIT: from BC, Canada) lifted one and made it into a desert buggy. Really cool. I'll see if I can find the pic. May be one of the ones you mentioned already though.
Here:
http://www.yarisworld.com/forums/showthread.php?t=58448
and...
http://www.subcompactculture.com/201...ota-yaris.html
Old 01-02-2019, 10:26 PM   #45
myfirstyota
Yaris overlander he called it. I believe he's in BC. The pics floating around of him were taken in mexico from what I remember reading. I think he even posted here although not an active member.
Old 01-02-2019, 10:33 PM   #46
06YarisRS
Right. That looks high with just 1.5" lift. I can only imagine a 'mini monster truck' 3" - 4" lifted Yaris!
Old 01-02-2019, 10:52 PM   #47
myfirstyota
I'm not exactly sure how high blucar sits over stock height. But it is taller than stock. It went from being lowered on tein stechs right to xD springs so its hard to tell. The strut assemblies are the same height as the Yaris (uninstalled) but the springs them selves are much thicker. Keeps the car from squatting as much as the OEM Yaris springs. That's the only reason those tires fit lol
The ride is not bad. A little softer than the stechs but stiffer than stock. So its lifted and handles :)
Old 01-03-2019, 12:39 AM   #48
myfirstyota
...You may have seen it already, but I think some guy down south or in Australia (EDIT: from BC, Canada) lifted one and made it into a desert buggy. Really cool. I'll see if I can find the pic. May be one of the ones you mentioned already though.
Here:
and...
Yep. Seen those. Totally got me wanting to make a road legal side by side but with heat hahah. Both my first Yaris and the blucar were lowered through winter. Not the most practical when 6" of snow is possible overnight. 26" in the Maritimes lol
Old 08-02-2019, 10:09 PM   #49
myfirstyota
Updates very soon!!
Im back wrenchin' again!!
I've installed the rear axle, rear disk brake setup, ebrake cables, and braided lines where available. All from a 2012 yaris SE.
So far everything has gone as planned and fits perfect except for the ebrake cables. Theres some bracketry issues.
A couple of these guys need to be removed from your old cables and swapped to the new ones. Not hard. Pry them off with a screwdriver and a pry bar and squeeze onto new cables
I just flattened this one to make it work
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
Old 08-02-2019, 10:35 PM   #50
06YarisRS
Updates very soon!!
I've installed the rear axle, rear disk brake setup, ebrake cables, and braided lines where available. All from a 2012 yaris SE. So far everything has gone as planned and fits perfect except for the ebrake cables. Theres some bracketry issues. Stay tuned for details.
Staying tuned in...
Old 08-12-2019, 09:21 PM   #51
enviri
enviri's Avatar
Drives: 2010 Yaris
2012 rear axles fit physically without issues eh? i was worried about mounts not lining up.
Old 08-16-2019, 06:46 PM   #52
myfirstyota
I certified the car today.
All parts on the rear axle are from the 2012 yaris SE model. Everything seems to work properly. The only issue I ran into was the e-brake cables. The cable mounts have to be removed from the existing drum brake cables and installed on the disk brake cables. Iirc, there's one mount on the disk brake cables that can just be bent to make work properly. The other 3 need to be removed from old cables and reinstalled on new cables.
Old 08-16-2019, 06:48 PM   #53
myfirstyota
So yea, the car is now plated and driving. Wow! I love the way it pulls! This engine should have been an option in North america!
All that's left to finish the build is a stereo. I have most of the components, just gotta get them installed. The a/c also needs to be refilled with refrigerant.
I didn't take many pics of the reassembly of the car. Its pretty basic stuff. One little surprise that wasn't mentioned in the first couple of posts I made for this thread is the full magnaflow mandrel bent 2&1/4" enhaust I installed with a new o2 sensor. If you plan in ordering this exhaust, make sure you get the one for the XD. The manifold flange is different size for the 1nz vs. The 2zr. The exhaust is otherwise the same and bolts right in. Even with the factory xd muffler and stock air box, it has a good sound.
I have brand new nitto neo tires in a 205/50/15 and it still breaks loose with no problem lol
Old 09-16-2019, 05:57 PM   #54
myfirstyota
Donor car on it's way to auto heaven
A couple shots of the finished product
The introduction
Here you can see the rear fog light mod.
Totally need to clean the amp and replace the battery
There's a couple new pics in post #49 too
The 2zr-fe engine swap guide ArmstrongRacing Performance Modifications 398 06-03-2019 02:36 PM
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 217 03-17-2016 08:49 PM
Post Whores-aka Yaris chat thread Black Yaris Off-topic / Other Cars / Everything else Discussions 21 07-12-2007 05:37 PM
engine swap?? thread deleted?? we-to-11 Off-topic / Other Cars / Everything else Discussions 6 06-25-2007 07:34 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
