Old 09-04-2019, 02:16 AM   #1
SoCalSTEVE
Drives: 2012 Yaris SE
Question 2012 Yaris SE Firing Order - Troubleshooting P0304 Code
Troubleshooting a P0304 code and wanted to verify the firing order is 1,3,4,2 with 1 being on the passenger side.
Thanks
SoCalSTEVE is offline   Reply With Quote
Old 09-04-2019, 07:07 AM   #2
ex-x-fire
Firing order & cylinder layout are two different things. #1 is near the belt & pulleys, #4 is at the opposite end.
Old 09-04-2019, 09:21 AM   #3
agreed, cyl 4 is on the transmission side, cyl 1 on the passenger/belt side.
best thing to do is swap the coil pack from 4-3 and the injectors from 4-2. see if the misfire moves or stays. they you'll know whether the issue is the spark plug, coil pack, or injector.
Old 09-04-2019, 04:40 PM   #4
SoCalSTEVE
Thanks for the clarification and info!
Old 09-04-2019, 07:28 PM   #5
SoCalSTEVE
Looks like the code cleared for a bit, but now it’s back. Going to swap the coil pack first and see what it does.
Old 10-24-2019, 07:07 AM   #6
SoCalSTEVE
Just an update swapped coils and spark plugs and turned out to be a plug causing the misfire.
What is it about the Yaris Ranger SVO General Yaris / Vitz Discussion 18 01-06-2015 10:45 PM
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW VitzBoy General Yaris / Vitz Discussion 5 09-05-2010 08:53 PM
True of False.. a dealership in the US can order you a Yaris xed New YARIS Purchase Forum 16 09-21-2007 12:28 PM
Copyright ©2000 - 2020, vBulletin Solutions Inc.
