Old 11-18-2019, 08:30 PM   #1
mint_julep
Drives: 2007 Yaris Hatchback
Rougher Idle with Increased Electricity Use
Is it normal for this car to have a rougher idle when anything electric is being used?
For example, if I'm sitting at a stoplight, and idle is normal, if I use the power window buttons (let's say 'up,' even if the windows are already up), as long as I hold them down the engine idle is definitely rougher. Not anything super bad, but you can definitely feel it. Or when i turn the steering wheel (electric power steering), or when the radiator cooling fan comes on/off, or when the turn signal is on, or even when the lights (both normal and low) are on.
I've replaced the MAF sensor, got that fancy K&N air filter, had the throttle body cleaned (also induction service, etc.), hell even had the fuel filter and pump replaced (purely preventative, nothing wrong with it, though def. time for the filter).
Any ideas?
mint_julep is offline   Reply With Quote
Old 11-18-2019, 09:21 PM   #2
myfirstyota
3 Yaris and counting..
It's normal.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
Old 11-18-2019, 10:28 PM   #3
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Yes normal. My 2014 has behaved this way since new.
Old 11-20-2019, 05:01 PM   #4
mint_julep
Gotcha. Gives me some peace of mind to know it's not just me. Thanks, ya'll.
DIY - 1.8L 1ZZ-FE TB Connector Chip Swap Yaris T-Sport DIY / Maintenance / Service 332 04-03-2022 01:39 AM
Erratic/High Idle twitchyboy DIY / Maintenance / Service 11 11-22-2015 12:14 PM
Fix For Low Idle When Warm On A Yaris Mk1 danielbb DIY / Maintenance / Service 0 06-12-2014 04:13 PM
rough idle.... dindy Third Gen Yaris General Discussion 5 06-12-2013 12:48 PM
3rd gen 1zz tb swap mr_miles DIY / Maintenance / Service 26 05-01-2013 08:20 AM
