Old 04-09-2016, 01:21 PM   #1
Cigar_Maverick
Cigar_Maverick's Avatar
Drives: 2007 Yaris Hatchback
NGK 5464 Iridium IX vs NGK 4996 Laser Iridium Spark Plugs
Buying new plugs for my 2007 Yaris. I've had it a week and it currently has 106,000 miles on it. RockAuto has the NGK 5464 Iridium IX for $5.93 & the NGK 4996 Laser Iridium for $6.07. At that price I was just wondering the difference? Preference?
Thanks,
Russ
Cigar_Maverick is offline   Reply With Quote
Old 04-09-2016, 01:37 PM   #2
bronsin
bronsin's Avatar
Any plug will last 100k now so it's moot.
Old 04-09-2016, 01:54 PM   #3
Cigar_Maverick
Hmmm. OK. Then I guess I'll just pend the 14 cents more for the better ones if everything else is equal. Thanks for the help!
Old 04-09-2016, 04:16 PM   #4
bronsin
bronsin's Avatar
My wife's Camry has 130k on the plugs and it's running like it did 12 years ago.
100k change interval.
Old 04-09-2016, 06:11 PM   #5
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Is that the car you can't get the plugs out of? LOL
Old 04-10-2016, 07:39 AM   #6
bronsin
bronsin's Avatar
THATS IT!
Old 05-21-2016, 05:29 AM   #7
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
i have the ix plugs when i got my Vitz RS counter parts from japan, ecu tuning, header etc. purpose of the plugs are to handle more heat/heat range...if you abusing your car like me or turboed, go for higher range plugs like ix or laser 😀
Sent from my SM-J700F using Tapatalk
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
Old 05-21-2016, 04:01 PM   #8
sickpuppy1
Drives: 2010 Yaris Sedan
interesting, if you go to the ngk web site it shows the 4996 as OEM and the 5464 as on option
Old 05-21-2016, 04:07 PM   #9
sickpuppy1
same heat range,same gap, same resistance, but the 4996 has a 8mm center electrode for longer life, where the ground electrode of the 5464 is tapered for "faster starts and better acceleration". !!?? I blew up the pic and the ground is tapered,sure as heck. So if I take a dremel to the ground on the 4996 do I get a faster,longer life plug?
http://www.partcat.com/ngk
Bigger Spark plug? samuraivince Performance Modifications 6 08-05-2014 04:09 PM
bought iridium spark plugs but need help Shinare DIY / Maintenance / Service 24 08-05-2013 12:21 AM
So You Just Have To Have Iridium Spark Plugs eh? bronsin General Yaris / Vitz Discussion 32 04-17-2012 02:14 PM
Laser plugs? - Awesome Altitude Off-topic / Other Cars / Everything else Discussions 1 04-24-2011 08:02 PM
Where do I buy ngk iridium tip 7 heat spark plugs? PETERPOOP Performance Modifications 23 03-08-2009 08:34 PM
