Old 03-18-2014, 03:36 PM   #1
spookybathtub
Drives: 2007 Yaris HB
Turn signal auto-shutoff not working
I took my steering wheel off to replace a broken spiral cable. I haven't found a replacement cable yet, but I put the wheel back together to drive it in the meantime. Now my turn signals won't shut off automatically after making a turn; I have to shut them off manually. Is this feature somehow dependent on having a spiral cable in place, or did I break something?
spookybathtub is offline   Reply With Quote
Old 03-18-2014, 03:58 PM   #2
It is dependent on the spiral cable being present.
Old 03-28-2014, 04:17 PM   #3
spookybathtub
How interesting. You're right, it's fixed after replacing the spiral cable. How does that work? There aren't wires for it in the spiral cable, so I thought it had to be mechanical.
Old 03-28-2014, 04:47 PM   #4
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
I don't know the Yaris' mechanism, but mercedes used a small plastic pin in the 80's that flipped out and was pushed aside by a tooth in the steering mechanism.
Maybe the spiral cable assembly provides this tooth?
dj92 is offline   Reply With Quote
Old 03-28-2014, 07:49 PM   #5
^Exactly - It is just a simple plastic tab that knocks the turn signal lever back.
Old 09-23-2017, 07:55 AM   #6
colblu44
Bruce
Drives: 2008 hatchback and sedan
How hard to fix?
I have never removed anything from my steering column, but now my right turn signal won't self cancel. Can I fix this myself? Should I replace the whole unit? Any instructions posted anywhere?
colblu44 is offline   Reply With Quote
Turn signal audible alert paultyler_82 Performance Modifications 7 10-01-2006 10:21 AM
