Old 11-11-2015, 06:21 AM   #1
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Finally something broke
The first thing outside scheduled maintenance is the knob that controls which way the heat comes out of which vent,it seems to have become disconnected from whatever it was connected to, after 220K thats not bad reliability.
Any one else have this problem or know how fix it?
Thanks
Its the one on the upper right with the A/C button in the middle=
http://0.tqn.com/d/cars/1/S/B/Y/ag_0..._s_ac3dial.jpg
Have Yaris will travel..
Old 11-11-2015, 08:41 AM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Check under the dash for the cable connected to the air box. I think I've heard of it coming disconnected.
Old 11-11-2015, 09:40 PM   #3
CB900F2
Drives: 08 Sedan
Thanks
Hi jambo.. I have the same issue.. I took apart the dash and my issue is that the insulation came out of its mount and it get stuck some times..
The cable assembly can be easily removed from the control knob, the issue is finding a way to disconnect it from the hvac box deeper inside the dash with minimal disassemble..
Anyone out there has any suggestion(s) for us?
Sent from my Z30 using Tapatalk
Old 11-11-2015, 10:52 PM   #4
CB900F2
Drives: 08 Sedan
Size:  177.9 KBName:  ImageUploadedByTapatalk1447300363.884906.jpg
Old 11-13-2015, 02:19 AM   #5
jambo101
jambo101's Avatar
Thanks for the pics CB. its clearly a job thats beyond my capabilities and if taken to a mechanic looks expensive to repair. fortunately the position seems to have locked in the defrost/ foot position,i think i can live with it.
http://images.wrenchead.com/Smartpag...T/29-71904.jpg
Old 11-13-2015, 05:57 AM   #6
bronsin
bronsin's Avatar
Looks like a bomb exploded but I think if you search for a procedure youll find its not as hard as it looks.
Old 11-13-2015, 09:26 AM   #7
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
When it's on one of the defrost settings, doesn't it make the AC run?
I thought I remember reading that's how the Yaris works.
Old 11-13-2015, 10:45 AM   #8
jambo101
jambo101's Avatar
Yes it will cycle on and off, not sure of the frequency but that defrost/ foot position has been my basic default setting since i bought the car new,doesnt seem to be a problem.
Old 11-13-2015, 12:41 PM   #9
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Yes AC will run. Most cars are set up like this.
NYC-SE is online now   Reply With Quote
Old 11-13-2015, 03:50 PM   #10
ern-diz
ern-diz's Avatar
That's what I thought I remember reading. Thanks for confirming.
I'm sort of the same way in that I'm almost always running the AC.
Old 11-14-2015, 07:12 AM   #11
bronsin
bronsin's Avatar
Defrost off on my 09 Yaris: 36 mpg summer, intown driving.
If I forget to turn the defrost off: 32 mpg ditto.
Old 11-25-2015, 12:18 PM   #12
jambo101
jambo101's Avatar
Fixed it, evidently a cable came loose, the mechanic re attached it , charged $45
Old 12-04-2015, 11:27 PM   #13
CB900F2
Drives: 08 Sedan
Hi Scott...
Based on your experience, is there enough room where the other end of the defroster damper control connects too between the haves of the HVAC body(see pic) to unsnap the control to remove it with our having to take maybe the one half(right side) apart?
And if so, do you know where the snap legs are located on the end so I can get a good idea if I can reach inside and press the hold to un latch the control end?
Old 12-05-2015, 06:43 AM   #14
bronsin
bronsin's Avatar
A reasonable happy ending!
Old 12-26-2015, 12:30 PM   #15
inamoto
Drives: bmw x5
interesting thread, I too was having the same problem
inamoto is offline   Reply With Quote
Old 12-29-2019, 09:34 AM   #16
CB900F2
Drives: 08 Sedan
Hey all.. Wanted to see if anyone has been able to replace the Defroster Damper Control cable assembly with out having to take apart the entire dash and top dash cover??
Mine finally fully gave out!.. So I am forced to replace it now..
Thanks all!!!
Old 03-09-2020, 04:35 PM   #17
LikeCaseyJones
LikeCaseyJones's Avatar
Drives: 2009 Toyota Yaris Sedan
Mine does this every 1-2 years. Just reattach it, takes like 10 minutes. Haven’t figured a permanent fix yet.
LikeCaseyJones is offline   Reply With Quote
Hose for windshield wiper broke HDS DIY / Maintenance / Service 1 04-06-2012 10:26 AM
Broke Some Plastic While Installing Hitch -- Fix? longmontrunner DIY / Maintenance / Service 5 04-14-2011 02:31 PM
I finally waxed my Yaris.... RedRide Photo-Video-Media Gallery 10 11-24-2010 12:16 PM
Finally broke 40 mpg brg88tx Fuel Economy Forum 5 07-16-2010 08:34 AM
Yay finally got my YRX (photos) Spikeles Australia 15 11-12-2008 03:16 AM
