12-06-2016, 03:54 AM | #19 |
Drives: vitz rs Join Date: Apr 2011
speed
Hi bro, u need higher top speed u ecu remap is last job.. I mean if u have n/a engine.. do u have 1.5 1nzfe? U need hi lift cams.. I can help..
12-06-2016, 04:08 AM | #20 |
speed
u need your engine to make higher revs and so power.. if u put longer final without increasing engine performances u go bad acceleration and u need too much to reach same speed as now but worst probably u don't improve any speed..
03-13-2017, 07:45 PM | #21 | |
Drives: 2012 Red 3 Door Hatch Manual Join Date: Mar 2017
Swapping ECM in America?
Is is possible to swap out my Japanese ECM for an American/Canadian/Puerto Rican one so I it will then have cruise control in the ECM? I bought the car in America and it has a J (for japan) on the first slot of the VIN, I am assuming that the computer was built in japan and doesn't have these features built in. But it makes sense in my head that if I found a manual ECM programmed in America then it would swap over without a hitch. Can you help? |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Need Help with 2NZ ECU pinout | Aleil | DIY / Maintenance / Service | 3 | 12-28-2020 09:40 AM |
I finally cracked the Odometer and SRS ECU code | CTScott | DIY / Maintenance / Service | 22 | 10-27-2016 01:50 AM |
standalone and stock ecu | Radou | Performance Modifications | 0 | 06-16-2013 04:47 PM |
Yaris ECU broken??!!!!!! | phb10186 | General Yaris / Vitz Discussion | 30 | 05-26-2010 09:56 AM |
Tricking the ECU to Relearn AF map | gwasabi | Performance Modifications | 126 | 05-16-2009 06:15 PM |
