Old 11-04-2016, 11:49 AM   #181
nieltown
Drives: Yaris 2008 Sedan
2008 sedan - acquired in late 2009.
Had brake booster issues with it in 2011, but no other problems whatsoever since then other than a squeaky serpentine belt which was replaced last year.
Still looking for the wire harness for the head unit so I connect my OEM aux port I acquired years ago. If you have one, hook me up! I've already been shut down here but I figure it's worth a shot:
http://www.yarisworld.com/forums/sho...559#post763559
nieltown is offline   Reply With Quote
Old 11-07-2016, 04:04 AM   #182
Bony_ahmed
Drives: Toyota Yaris SEdan
115k.......still kicking ass :P
Bony_ahmed is offline   Reply With Quote
Old 11-07-2016, 07:37 AM   #183
BennyLava
Drives: 1987 Silverado
161k on 2009 sedan. Bought the car with 40k on it.
My list of troubles are few. But here they are:
1. Front suspension. The shocks were somehow worn out even though the car only had 40k on it, when we got it. Replaced those.
2. I need to replace a ball joint.
3. Belt started squealing and has been replaced. Still squeals sometimes though...
4. Center console door screws backed out. Took it apart, tightened the screws, and haven't had any trouble with it staying shut since then.
5. Headlights having to be polished out.
6. Some of the rubber door seals letting go and flopping a bit. Siliconed them back down.
Old 11-07-2016, 08:34 AM   #184
nieltown
Totally forgot - had my belt replaced last year and the problem has gone away. However, this YouTube video suggests it may not be your belt at all:
https://www.youtube.com/watch?v=HRrVMtyIqIY
Forgot to mention this as well - the seal on one side (roof along top of door) has basically rotted out with just some wire there. I need to replace it - they're not expensive, I'm just a lazy dirtbag.
Anyway, right on! 161k is a lot of miles.
Old 11-22-2016, 02:43 AM   #185
CincyC6
Drives: 2008 / 2011 / 2012 Yaris
294k
Alternator went out at 289k, only other stuff is multiple drive belts, axle, brakes, etc. Very solid car
CincyC6 is offline   Reply With Quote
Old 11-26-2016, 03:57 PM   #186
Dragonslayer182
Teal Squealer
Drives: 07 Yaris Sedan
Car is at 103,700k miles right now. It hit the 100,000 mark back in January.
Dragonslayer182 is offline   Reply With Quote
Old 12-07-2016, 02:09 PM   #187
humayun.chughtai.7
Drives: Toyota Echo 2001 4-door
My toyota echo 2001 clocked 473,700 KM's till today. And it's still going strong with original engine :)
humayun.chughtai.7 is offline   Reply With Quote
Old 12-08-2016, 09:17 PM   #188
CincyC6
A friends Echo had 350k miles and was just t-boned this week. Still ran like a top
Old 12-12-2016, 06:36 PM   #189
billfires
Drives: 2010 3dr LB
Just turned 110,000 miles on my 2010 5 speed HB. Oil and filter changes every 5K with synthetic oil, tires and an air filter are the only maintenance items done. Original brakes and battery still. Bill C
billfires is offline   Reply With Quote
Old 12-12-2016, 06:54 PM   #190
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Nice
On Instagram
On Wheelwell
Old 12-13-2016, 11:35 AM   #191
bryanhoule
Drives: 2007 Toyota Yaris MT LB 2-door
121,000 miles. 2007. Love the Yaris!
bryanhoule is offline   Reply With Quote
Old 12-19-2016, 12:01 PM   #192
mark293
Drives: 2007 THREE DOOR 5 SPEED
@198xxx
replaced A/C compressor and associated items after hearing a warbling noise. In addition to the A/C, it was determined the the water pump needed replacing. Still on the original brake pads.
Haven't been on the forum in a while, no need to, lol! I think I might buy the "egg" some weathertech floor mats for Christmas. That, or a headlight polishing kit.
mark293 is offline   Reply With Quote
Old 01-01-2017, 01:20 PM   #193
man83
Drives: Yaris HB
82,xxx miles 2008
Enviado desde mi SM-G920I mediante Tapatalk
VELMAX member.
man83 is offline   Reply With Quote
Old 01-24-2017, 02:02 PM   #194
Jalapeno08
Drives: Yaris Sedan 08
100+ mileage
Bought my Yaris sedan in 2008 and so far at 135k miles I have had zero issues that doesn't involve the usual maintenance. Biggest necessity so far was changing the brakes. I also have a Rockford Fosgate amplifier and my second subwoofer and still have its OEM battery.
Jalapeno08 is offline   Reply With Quote
Old 01-24-2017, 04:50 PM   #195
soldout
soldout's Avatar
Drives: 2010 Blazing Blue 3 Door LB
I'm over 135000 with all the driving I do for work. The only things ive replaced is the battery about 6 months ago. When I got the car it was already 3 years old and my stereo system probably didn't help extend its life. Also the front rotors and pads had to be replaced on my last inspection, they had over 110,000 miles. Other then that just your usual tires, spark plugs, changed the brake fluid, still need to flush the coolant. Car has been absolutely flawless except for the day the battery just quit on me, luckily it was parked in my garage and didn't leave me stranded on the side of the road. I'll probably replace the asscessory belt this year just for piece of mind.
15' - Crosstrek Hybrid ~ Plasma
10' - Yaris 3 Dr LB ~ The Boom Box
06' - RSX Type S ~ H.S. Dream Car
95' - Delsol VTEC ~ The Racecar
12' - Burgman 400 ~ Garage Queen
09' - Agility 125 ~ 80mpg Daily Rider
09' - Metropolitan ~ Weee
14' - Ecosmart Metro ~ Razor
soldout is offline   Reply With Quote
Old 01-24-2017, 04:54 PM   #196
tmontague
tmontague's Avatar
At 173k km now. Only things replaced so far are the battery and water pump.
This summer I'll be replacing rotors and drums and upgrading front pads. Rotor and drums are rusted to help so the new one will get a coating of paint.
The puck bushings on my control arms are starting to have small cracks in them and are due to be changed. I'll be upgrading to whiteline control arm bushings this summer.
Old 01-24-2017, 05:00 PM   #197
miiser
miiser's Avatar
Drives: yaris 2009
105.000 2009 100hp 5door hoho
miiser is offline   Reply With Quote
Old 04-18-2017, 07:33 PM   #198
Blooshoo
Drives: 2008 Hatch
175,9xx on my '08 3 door 5 speed. Rear ABS sensors right after warranty ($1000, grrr), Replaced water pump at 95k. The dealer was going to replace the timing belt on schedule, but when they opened it up, there was a chain! They put in the water pump just because, and sent me on my way. Mostly 40 mpg. Solid little car, but I miss my '94 Geo Metro 1 liter 5 speed...50 mpg...
Blooshoo is offline   Reply With Quote
Mid-West Chapter Micro Image Car Club lilredrocket Southwest 10 10-05-2009 01:06 PM
30,000 mile service: Dealership or non-dealership? EstherK DIY / Maintenance / Service 1 11-12-2008 12:40 PM
11/02/08 Metro Auto Squad 1st Annual Car Show (my car club) Jerkratt NY / NJ/ CT / PA 14 10-26-2008 05:51 PM
Japanese Mix Club Los Invitamos!!! TunTun_yariS[PR] Caribbean 0 12-12-2006 12:03 PM
Buddy Club Wheels BulletProofAuto Sponsors Classifieds Area 8 10-19-2006 06:55 PM
