Old 01-01-2017, 04:18 PM   #1
vwhugger
Drives: 2008 and 2012 Yaris 2dr
!4" wheels?
I have 2008 and 2012 Yaris' and both have 15" tires, 185-60r15 and 175/65r15 respectively. In the owners manual for the 2008 they also mention a 14" tire and wheel. Would that be for the Canadian market only? Anyhow, I have 175/65r14 snow tires from my VW's that I was thinking of using on my Yaris'. I never see any 14" steel rims for sale in the used market. Where are they all? Hope this made sense. I think it's my first post on this forum.
vwhugger is offline   Reply With Quote
Old 01-01-2017, 05:15 PM   #2
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
14" wheels are standard on the 1.3 litre 2NZ-FE engined models here in Australia. The models with the 1.5 litre 1NZ-FE engine get 15 inch wheels.
For the third generation models, the standard tyre sizes here are 175/70R14 or 175/65R15. The second generation may have had different sizes. A number of VW models had the same wheel stud pattern and similar inset on the wheels. If this is what you have, they should fit.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 01-01-2017, 06:20 PM   #3
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
The very base of the US Yaris in 2007 supposedly came with 14" wheels, but good luck actually finding one. I run 14" wheels and tires on my Yaris, they fit but the clearance is comically tight. Tire rack will let you buy them and they are insanely conservative with that type of stuff.
Colin Chapman disciple
Old 01-01-2017, 07:08 PM   #4
kimona
kimona's Avatar
Drives: 2014 White VITZ
These 14" wheels may work for you: http://wausau.craigslist.org/wto/5938623895.html
Maybe they are in your area.
Old 01-02-2017, 07:07 AM   #5
Canadian non-RS models has standard 14" Steel wheels with 175-65-14 tires from 2006 to halfway thru the 2008 model year when they switched to 15" steelies like the USA.
14's fit fine on 2008, I haven't kept up with it as much since selling my 2007 in 2013, but unless the calipers have changed, your 2012 should be ok too
Old 01-04-2017, 11:55 AM   #6
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
I run 14" steel wheels on my Yaris for winter. They came from a Honda Civic. Fits fine.
Old 01-04-2017, 12:20 PM   #7
vwhugger
Ok, thanks for all the info and suggestions.
Old 01-24-2017, 01:34 PM   #8
RichardPan
Drives: Toyota Yaris 2007
My 2007 Yaris came with 14 inch steel wheels. Bought it in 2010, and immediately bought another set of 14 inch wheels with X-ice winter tires. When it came time to replace the stock all-seasons, Costco had exactly one type of tires for my Yaris. The price was good, and it lasted 6 seasons before picking up a nail and developing dry rot. Now it's time to buy all-seasons again. Canadian Tire near me only had Michelin Defender or MotoMaster AW2 in stock for my size. All else would need to be ordered. They do seem to have wheels in stock though. So it seems such wheel and tire sizes are not too difficult to find in Canada, yet.
RichardPan is offline   Reply With Quote
Old 02-28-2017, 06:39 PM   #9
yarisimean
Drives: 2012 Yaris 3d LB
Don't mean to thread jack, but had the similar question as OP.
Was wondering if Enkei RPF1 14x7 et28 or et19 mm would fit on 2012 yaris.
I was thinking either 185/60r14 or 195/60r14 for tire sizes. Thanks.
yarisimean is offline   Reply With Quote
Old 03-01-2017, 08:59 AM   #10
will poke...didnt realize rpf1's came in 14"
ive run 14x6 alloys on my yaris without issue...and et28 and 19 should put it past the calipers
Old 03-01-2017, 09:14 AM   #11
consider kosei k1 ts wheels...had them on our aveo....
Old 03-01-2017, 09:04 PM   #12
yarisimean
What will it poke?
BTW those kosei look pretty good.
Old 03-02-2017, 06:32 AM   #13
'Poke' means the wheels will stick out past the fenders.
Old 03-02-2017, 05:24 PM   #14
yarisimean
oh ok. thats what i was afraid of.
Old 03-02-2017, 08:03 PM   #15
kimona
kimona's Avatar
For your 2012 Yaris:
OEM: 185/60/15, 15x5.5, ET45 (tyre diameter = 23.7")
RPF1: 185/65/14, 14x7, ET28 (tyre diameter = 23.5")
RPF1 wheel/tyre package will poke out 17 mm (0.7'') farther.
Old 03-03-2017, 05:39 PM   #16
yarisimean
Thanks for the great info. 0.7" doesn't seem too bad then, I'm hoping it doesn't rub. I'll update once I get the wheels.
Old 03-03-2017, 07:16 PM   #17
kimona
kimona's Avatar
^^^ For your reference: I have 16x7, ET42, 205/50/16.
This wheel/tyre set-up pokes out 13mm (0.5'') farther, and I have absolutely no issues on my 2014.
So, with 17mm (0.7"), you should have no problems with 14x7, ET28, 185mm rubber.
FS: Mini Cooper 5 Spoke Wheels with Tires, Hubcentric Rings and Lug Nuts CTScott Items for Sale by private party 14 08-17-2012 11:18 PM
FS: 15x7" Advan Kreuzer xii Wheels - New - Various - Cheap jtf1986 Items for Sale by private party 21 08-15-2011 02:30 PM
