04-20-2017, 04:27 PM | #1 |
Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
aftermarket ball joint for lower applications
Has anyone been able to fine ball joints that are extended over oem so improve the roll center in lowered Yaris'?
My ball joints will need to be done down the road and I figured since I'm lowered an experience some bump steer, I'd try and source some ball joints that help correct the control arm angle. Problem is I haven't been able to find any online. Has anyone found or used an extended ball joint on their Yaris and is there any other options for us lowered yaris guys?
No one ever wants to give a Yaris the point by... |
04-20-2017, 09:04 PM | #2 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Thats on my to do list along with sperical bushings to replace the whiteline crap
Probably going to use screw in mopar style and ream the spindle to accept.
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
04-20-2017, 09:34 PM | #3 |
What wrong with your whiteline bushings?
04-20-2017, 09:44 PM | #4 |
Obsessed with 1.5L
They suck haha
04-20-2017, 09:51 PM | #5 | |
Drives: 2015 H Production Yaris Join Date: Oct 2009
http://www.yarisworld.com/forums/sho...ht=ball+joints If the bump steer is what you are worried about opt for the steering links, because moving the ball joint just lowers the control arm, it does not correct the steering angle.
2005-2008 SCCA Solo BS National Champion 2017-2018 SCCA H Prod National Champion |
04-20-2017, 09:54 PM | #6 |
Did you ever run the one from the japan?
If I could get the dimensions of the oem one I'm sure there are others that would fit into a Yaris control arm that are longer and correct the roll center. Jason, are you just using the oem ball joints?
04-20-2017, 09:57 PM | #7 |
I have not changed any of the joints or bushings, all OE. *Except the upper strut mount, replaced those marshmallow with the Cusco units.
04-20-2017, 10:03 PM | #8 |
Good to know, thanks
04-20-2017, 11:56 PM | #9 |
there was a company in japan called MOONFACE that made ball joint and control arm assembly for our lowered cars..
edit: here's the webpage. no more control arm. http://www.superlap.jp/item_detail/2/ they also do tie rod ends. |
12-17-2019, 12:48 PM | #10 | |
Drives: 2012 Sedan Join Date: Nov 2018
have you gotten to try them? |
12-24-2019, 10:07 PM | #11 |
Obsessed with 1.5L
I should of been more specific...the rears separated within the first year of use. So i get an occasional clunk (or slap) under very hard braking. They really do not seem to move about or go anywhere, however I feel there is improvements to be had
12-25-2019, 12:07 PM | #12 |
wow, i was/am getting a similar noise. i knew it had to be because of the bushings but i didnt know specifically what. i dont think i will be changing them though. Based on what you stated, which ones do you feel would have been ideal?
12-26-2019, 11:17 AM | #13 |
No I haven't had any luck finding them
12-28-2019, 04:05 PM | #14 |
Obsessed with 1.5L
I haven't really looked around. By the design the rears are goofy AF...and even harder to figure out a better solution. Id be interested to see if SuperPro has a better design then WhiteLine. The front bushings are pretty normal and straightforward tho I have no problems with them.
Thread Tools | |
Display Modes | |
Similar Threads | ||||
URGENT. BALL JOINT REINSTALLATION QUESTION | xb visitor | DIY / Maintenance / Service | 4 | 05-09-2014 06:02 AM |
Wheel Bearing Replacement (FRONT) | justjesus | DIY / Maintenance / Service | 11 | 04-26-2014 07:38 PM |
Front Lower Ball Joint Cotter Pin Replacment | GrayYaris | DIY / Maintenance / Service | 5 | 04-25-2014 04:30 PM |
Putting on dust cover boot ring on ball joint | yaris4062007 | DIY / Maintenance / Service | 10 | 04-21-2013 12:51 PM |
Ball Joint on Bottom Arm | David Godfrey | DIY / Maintenance / Service | 1 | 04-18-2010 06:27 PM |
